Gas Mileage Deterioration
Discussion in 'Gen 2 Prius Main Forum' started by bee-eater, Oct 21, 2017.
Tags:
  1. bee-eater
    bee-eater New Member
    Sharon, CT
    I'm the new owner of my first Prius, a 2009, with 80K miles. (I'm embarrassed to say I don't know what model, I just guessed.) I'm seeing a drop in gas mileage over the past month or so. From a peak of just below 50 to now hovering around 45. (I've never gotten over 50 as some people seem to.) My driving habits really don't change. I have a long (nearly 2-hour) commute on mainly highway usually 2x a week, with lots of hills, and a good amount of local travel ranging from a few minutes to 45 minutes or so.
    This seemed to happen in the weeks before my last service, then temporarily improved, and is now dropping again. I'm only halfway to my next service. One of the things I notice is that when starting out for the first trip of the day the battery doesn't kick in for a minute and the mileage is like 10 mpg. We're having the first cooler mornings -- could that be a factor?
    Only one other change: the plastic shield that I'm told pushes air up into the engine compartment tore off. (This apparently happens a lot because it's so low to the ground.)
    Help? I've seen mentions of "inverted coolant" -- I don't even know what that is. Thanks.
    52,393
    welcome!
    winter temps can reduce mpg' up to 20% or more. so cooler mornings could be part of it.
    lack of the shield reduces aerodynamics, another factor.
    check your tyres pressure.
    inverter coolant keeps the inverter cool. there is a reservoir under the hood on the firewall. check it when checking all your fluids when gassing up.
    make sure your air and cabin filters are clean, and the oil level is between the high and low marks.
    all the best!(y)
    jerrymildred likes this.
  3. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    A Gen2 Prius (2004-2009) usually averages 46 MPG, not 50. It will get somewhat better MPG in mild weather and get less in cold weather. You should check the air pressure in your tires as tire PSI will drop at colder temperatures (This is a law of physics) and that will reduce your MPG as you noted. I always run my Prius tires at 42 psi in the front and 40 psi in the rear to maximize MPG, but it still drops in cold weather.
    As for "coolant" there are two independent coolant loops in your Prius. One cools the gasoline engine (ICE - Internal Combustion Engine) and the other cools the Power electronics unit that manages the electrical power that goes to/from the motor generators (there are two MGs). The power electronics perform several functions, one of which is to generate high voltage AC power from the 200+ V High Voltage (Traction) battery, This process is called "Inversion" so we tend to call the unit an Inverter.
    JeffD
    Raytheeagle and bee-eater like this.
  4. bee-eater
    Sharon, CT
    Thank you!!
    srellim234 and bisco like this.
  5. bisco
    52,393
    like your avatar.:)
  6. bee-eater
    Sharon, CT
    Thank you!!
  7. bee-eater
    Sharon, CT
    It's my favorite bird. Thanks!
  8. fuzzy1
    10,603
  9. bee-eater
    Sharon, CT
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The short hops are MPG killers. The engine has to run to get up to operating temp and to heat the cat. The colder the outside temp the longer it takes. Blocking the grill will keep more of the generated heat in the engine compartment. Search for "grill blocking" and you'll find a number of approaches.
    There have been winters where a 35 mile mostly highway commute won't keep the engine warm and waiting for a traffic light was long enough for the coolant temp to drop enough to cause the engine to fire up.
    Without knowing the particulars of your route there's no way to guess what you could expect. Just pumping in a "little extra" gas to round up a purchase or the bladder stiffening to take less to "fill up" will cause wild swings when measuring fuel economy tank to tank.
  11. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    50+ mpg is great but those who get it only show what is possible with their individual cars, not what you should expect from yours. Fuelly.com doesn't have an easy way to see what 2009 Prii still being reported are getting but the overall average for 2009 is 43.5. All the Gen II are in the 43-44 mpg range. Keep in mind that with those 50+ people in the mix there have to be enough under 43 to get the average down to where it is. It's great to want to improve but also be happy with your "above average" car. Enjoy it and don't fret too much about it.
  12. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    For the first minute the car is on (or longer if it's colder), the car operates in open-loop mode, meaning that it's not really using the sensors to determine fuel mixing and timing, and so runs the engine very rich and with conservative (fuel-inefficient) timing (Stage 1 Warm-Up). Once the o2 sensor and radiator water temp warm up enough to operate correctly, the Prius will get much better fuel economy(Stages 2-4). If you have to immediately go hard on the gas after starting, you'll likely get better fuel economy by starting the car and waiting a minute before driving off. See this for a full explanation on the Prius warm-up stages: http://techno-fandom.org/~hobbit/cars/five-stages.txt
    Yes, all cars get worse fuel economy in the winter due to needing longer to warm the engine up to ideal operating temp, and that the air is actually denser, resulting in more aero drag on the highway.
    This one is definitely affecting your fuel economy. I had the exact same happen to me - it tore off on me on the interstate. I immediately started seeing about 5mpg less on the highway. After I fixed it (with lots of epoxy and some plastic sheets), fuel economy was restored.
    #12 Kevin_Denver, Oct 23, 2017
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    The shield under the radiator is not to force air its to keep road damage like rocks and debris from damaging the very expensive AC Condenser which sits in front of the radiator. Punctured condenser no AC and possible damage to the AC compressor. Its very important you have that shield installed. The G2 is very low to the ground and it will pick up alot of debris.
