Gas mileage
Discussion in 'Gen 2 Prius Fuel Economy' started by Beverly, Dec 1, 2013.
  1. Beverly
    Beverly New Member
    Boston, Massachusetts
    I recently had an oil change and my tires rotated on my 2006 Prius. Ever since my mpg has gone down from 45mpg to 30mpg AND I get a mere 90 miles on 1/2 a tank. WHAT could be the problem here?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Moved from the Prius v main forum to the Gen II fuel economy forum.
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Check your tire pressures, perhaps they are too low if they adjusted them at all from where they were. Also, it has happened to many a person after an oil change, check your oil level; Many times they add far too much oil above the 'top' fill line on the stick. One other question is are you still on the original 12v battery since the car was built?
    Just three immediate thoughts.
    Also, one more thought though I don't think it will pertain to you if you have owned the vehicle for a while... In winter with decreasing temperatures, MPG will always go down, though what you describe (30mpg) is still very low.
  4. Tony D
    Tony D Active Member
    468
    132
    Dublin, Ireland
    As stated:
    1. Low tyre pressure
    2. Too much oil
    3. Air temps dropped
    4. Winter tyres?
    Edit, this is a great site where you'll find all the answers from a very helpful bunch
  5. bisco
    49,501
    welcome to priuschat!
  6. Beverly
    Beverly New Member
    thanks!
  7. Beverly
    Beverly New Member
    thanks
  8. Beverly
    Beverly New Member
    I am still on the original battery and will be checking the tire pressure tomorrow... (will get back to you on that) I
    have an appt with my mechanic on thursday and will have him check the oil. thanks for the help!!
  9. Beverly
    Beverly New Member
  10. Beverly
    Beverly New Member
    Thanks
  11. fuzzy1
    10,172
    A 12V battery of that age is living on borrowed time. And this would be the time of year it is most likely to either fail or to cause various problems (including low MPG) as it nears failure.
    But don't blindly replace it without checking it first. It could just be old, but still adequately functional and not the cause of your low MPG.
  12. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Beverly likes this.
  13. Beverly
    Beverly New Member
    So here's an update on what I've done. I check the tire pressure and the front tires were a little low. Took care of that. Had my mechanic check the oil and it was right on the money (no overfill). And last but not least, I had the spark plugs changed. All this has eeked out a few more miles. I'm getting about 55 more miles per tank. I guess, its the heat, which I use all the time when I'm on the road. And since I drive for a living, I'm on the road a lot. Thank you all for your suggestions! Just having some options calmed me down...because I was hysterical when I first posted to the site.
    Data Daedalus and Tony D like this.
  14. ETC(SS)
    6,555
    Miss Beverly?
    WELCOME to Prius Chat, Ma'am!
    Take a look at the above questionnaire.
    It's COLD in Baston, but you should be getting better than 30-mpg!
    Good Luck!
  15. bisco
    49,501
    i would take a good look at the 12v battery, all the best!(y)
  16. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    ...well keep in mind there are 2 batteries, we're talking about the really small one, the 12v battery in the rear trunk area. Many of us change over to the Yellow Top Optima when the times comes, but it's a bit of a chore to change it yourself.
  17. Data Daedalus
    Data Daedalus Senior Member
    1,022
    1,183
    Wembley, London
    Hi Beverley! Just curious, so how's your Prius behaving of late with regards to MPG? I've noticed that my 2008 Prius has also dropped down to about 50mpg (driven more like a normal car) than back in summer when I easily achieved 66mpg.
    I've been experimenting with the heating and have discovered that particularly in cold weather, the higher the heating is, the lower the MPG tends to drop. This is far more noticeable when doing shorter journeys. On long distance journeys it's not that bad.
    You might want to consider blocking some of the grilles at the front of the car to help the engine retain heat so that it doesn't have to run all of the time - I'm sure you've been given this advice already by someone on this site already.
    I'm achieving 50mpg in the UK presently by keeping my heating controls set to a minimum of 19c and a maximum of 22c - the higher setting is for when I have passengers. The lower setting is for when I'm alone - though I've also dropped it as low as 18c once the interior is demisted. Don't be afraid to use the A/C to demist the interior - it does a great job very quickly and is very handy. Running the A/C in winter also ensures it stays healthy.
    Hope this helps.
    iPad ? HD
  18. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    Also, please feel free to set your heat at 85f or HI to warm the cabin initially, but once it warms up, decrease the thermostat to 72f. On my Prius, once I lower the cabin temp below 73f, the engine shuts off and I get better mpgs. If I leave it set to 85f or the HI setting, it kills my mpgs presumably because the engine is running non stop to keep it warm to give you heat.
    FWIW, the cabin comfort doesnt change much at all when set from 85 down to 72.
    Data Daedalus likes this.
  19. Skateruk
    Skateruk Member
    125
    28
    Nottingham, UK
    Hi Beverly, I don't know how long you have owned the car, but did you alter your driving style recently which has coincided with the oil change and tyre rotation? Just another thought. It might be a combination of all the various points raised above and perhaps you have to do a bit of fine tuning somewhere! Good luck.
  20. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    I'm thinking 12v battery also.
