Gas pedal too soft
Discussion in 'Prime Main Forum (2017-2022)' started by Peng Xiao, Apr 12, 2019.
  1. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    I feel the gas pedal is too soft, have to lift my foot, make my leg not comfortable.
    My 2001 Accord and 2005 GX470 don't have this issue.
    Can the firmness be adjusted?
  2. KP7
    KP7 Member
    50
    42
    New England
    2018 Prius Prime
    I don't believe that you can adjust the firmness, but you can adjust the throttle response: Eco mode for least sensitivity, Normal mode for middle, and Power mode for most sensitivity. That might help it feel firmer if you don't have to depress it as much for a given amount of acceleration.
    Montgomery, Mendel Leisk and bisco like this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    No. No "standard" way at least.
    But are you sure that you don't mean the pedal it too STIFF ??
  4. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    I have the same problem (too soft, not stiff). Very uncomfortable keeping foot slightly lifted. I would think fixing this would only require a tighter spring. I'll ask my dealer about this at next service.
  5. audiodave
    audiodave Active Member
    787
    268
    US
    Newer cars all seem to be soft. Just the weight of your foot pushes it. Lol
    More feedback, resistance would be nice.
  6. Elektroingenieur
    2,515
    3,258
    Three Touring
    You’re welcome to ask, of course, and there is a spring, but the Repair Manual (more info) warns, “Do not disassemble the accelerator pedal sensor assembly.” If defective, it’s replaced as a unit. Considering Toyota’s history of unintended acceleration issues, I’d be surprised if any dealer would be willing to attempt internal repairs or adjustments not described in Toyota’s publications.
    #6 Elektroingenieur, Apr 13, 2019
    jb in NE and pghyndman like this.
  7. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    The pedal isn't intended to support the weight of your foot. But I have had a couple that were too stiff. If you find the place you want for the throttle, you just rest your heel on the floor and the side of your toe against the "hump" and let that do the supporting. It should require zero effort except to change speeds.
  8. KP7
    KP7 Member
    50
    42
    New England
    2018 Prius Prime
    I think I'm missing something here. Could those who are talking about a lifted foot explain more. We are all doing it like this, right?
  9. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    With my other cars, if I want to keep the speed at, for example 45 mph, I just rest my foot on the pedal almost without any effort.
    But with Prime, I have to lift my foot and hold that position. Otherwise, the speed maybe go to 70 mph.
    I used my hand to feel the pedal, it is softer than my GX470.
    #9 Peng Xiao, Apr 13, 2019
  10. Bob Comer
    Bob Comer Active Member
    708
    457
    South Carolina low country
    I'm curious about that too. I have always rested my heel on the floor on all my cars and I have a small foot for a man...
  11. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    I do rest my heel on the floor, but have to use a little effort to lift foot palm on the pedal, and hold that position
  12. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Move the seat back a bit
    Lee Jay and jerrymildred like this.
  13. jerrymildred
    11,508
    14,109
    Tampa, FL
    I can see how that might be a problem if you have your seat so far forward that your knees are up in the air and the seat isn't supporting the bottoms of your thighs. That would put downward force on your ankle which would lever down on the throttle. But in a proper position, your foot should be able to relax with the friction of the carpet on the side of your foot being sufficient to hold it in position. I have friends who sit super close and it's kind of scary because it puts them too close to the steering wheel also.
    Montgomery likes this.
  14. jerrymildred
    11,508
    14,109
    Tampa, FL
    I think we were typing at the same time, but I was verbose. :D
  15. bisco
    49,397
    did you ever try eco mode, as suggested by kp7 in post #2?
  16. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    I assume the gas is electric, not wire, I'd get a real sponge, rectangular, biggie. Velvro one end and stick it on the floor under the gas pedal, lot's of natural resistance.
    Or adjust the seat?
    Lower or raise it to get an angle that gives more blood flow to the foot.
  17. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I recommend a higher seat cushion and to adjust the angle your foot rests on the pedal.
    I honestly do not like the seating, especially for long drives but my seat cushion helps a ton. The seating is probably my biggest dislike.
    Otherwise a good car and I use the cruise control a lot to help with not having my foot on the pedals all the time.
  18. sam spade 2
    7,035
    2,788
    2017 Prius c
    Maybe you just need different shoes.
    Or you need to adjust your seat forward or back.
    I STILL do not understand why any part of your foot would need to be "lifted".......IF you are positioned right.
  19. jerrymildred
    11,508
    14,109
    Tampa, FL
    Ditto!
  20. KP7
    KP7 Member
    50
    42
    New England
    2018 Prius Prime
    OK I think I understand now. You aren't lifting your foot off the floor (which is what a lot of us on this thread were visualizing). Rather you are having to pull back the ball of your foot to reduce allerceration and maintain speed, leaving for foot/leg in an uncomfortable position.
    Does this correctly describe what is going on? If so, I'd reiterate previous advice: try eco mode so that you can depress the pedal further for a given amount of acceleration; adjust your seat position or height; try some different shoes.
    Personally I haven't had this problem. My bigger annoyance is that you need to maintain some pressure on the pedal to coast and avoid regen. Gets somewhat tiring around hour 2 or 3 of a road trip. Great feature in most cases--not as much on long trips.
