Gas prices are rising
Discussion in 'Gen 2 Prius Main Forum' started by Peterhans, Mar 5, 2022.
  1. Peterhans
    Peterhans Junior Member
    103
    Germany
    Some time ago, the hybrid battery was repaired before the Russia Ukraine crisis. Now I see gas prices at €1.9 / liter which is around $8.00 / gallon. I also noticed getting about 6.0 liter/ 100km which corresponds to about 39 mpg. Outside temperature has been around 5 C. What is your opinion on this? 2006 prius with 112,000 km.
    49,455
    it's more about your driving scenario, and relative to past mpg performance. 39mpg for a 16 year old car with a rebuilt battery isn't outside the envelope by any means.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    My opinion is when my battery finally failed I was getting 39 mpgs.
    In most posts on this site repaired means it was whack a mol'ed which means the modules that had failed were replaced with the same vintage year modules that are already in that car except they have not failed yet. Repaired always means its just a temporary thing because there is no brand new modules all that are available are the same G2 old modules except they may have been charged up enough to get the car down the street.
    Your new here use the search forums link up top and search:
    hybrid battery
    and read what thousands of people have already gone through what you are about to go through. Good Luck.
    Peterhans likes this.
  4. Peterhans
    103
    Germany
    I found newer modules on ebay and from the UK.
  5. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    39 mpg is bad. Short trips with cold temps can do this but if the car is driven for more than ten miles and still only getting 39 mpg, something else is wronged in my experience.
    Peterhans and jerrymildred like this.
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    @Another brings up a very good point. If you're making mostly short trips, 39 mpg would be normal. If you're making longer drives, I would expect more like 45-60 mpg, however that converts to metric. Colder temperatures will reduce fuel efficiency somewhat and even more so with short trips.
    If short trips are not typical, it may be a combination of things like tires (pressure & type), driving style, engine tune, etc. that are adding up.
  7. edthefox5
    10,096
    4,805
    Clearwater, Florida
    what’s newer modules?
  8. edthefox5
    10,096
    4,805
    Clearwater, Florida
    And yup it’s been WAM’ed.
  9. Peterhans
    103
    Germany
    I understand 2012 and 2013.
  10. Peterhans
    103
    Germany
    Most of the trips during the week are short trips. I try and get a longer trip on the autobahn. This helps in lowering the liters per 100km. By the way, currently gas prices are $8.1/gallon.
  11. Peterhans
    103
    Germany
    Newer than 2006.
  12. Another
    1,802
    511
    Naples, Florida
    At 112k km hard to believe plugs needed but maybe mass flow fuel sensor dirty?
  13. pasadena_commut
    pasadena_commut Senior Member
    1,485
    445
    Southern California
    39 mpg sounds reasonable if the outside temp is 5 C and the car is driven with the climate control set to 68F or so. In addition to the heat (energy loss) to the cabin the A/C is probably also cycling to keep the windows from fogging up. Even more so if the trips are shorter than say 5 miles, where the coolant would only barely have warmed up. Do you have a grill block? Might make sense to use one with temperatures in that range. (That part is theoretical for me, it is only rarely that cold where I live.)
  14. jerrymildred
    11,508
    14,110
    Tampa, FL
    Back to the gas prices, I saw that they took a big jump today. When we left home this morning, they were about $3.459. This afternoon they at $3.999. I think that's the highest price in this area I remember ever seeing. I have seen over $4 in other states.
  15. bisco
    49,455
    our local station jumped from $3.89 to $4.29 over the weekend, loving it.
    elon musk says pump more oil, down with elon
  16. Peterhans
    103
    Germany
    I replaced the plugs with platinum about a year or so.
  17. Peterhans
    103
    Germany
    Not sure of a grill block. Used to be in San Diego.
  18. Peterhans
    103
    Germany
    Try over $8 per gallon
  19. jerrymildred
    11,508
    14,110
    Tampa, FL
    That could explain your fuel economy. BTW, I'm pretty sure that the 2006 calls for iridium spark plugs like the newer ones.
  20. Another
    1,802
    511
    Naples, Florida
    $5 soon …
    But uncle Joe can’t get the oil flowing again here. Pathetic.
