Gas pump keeps shutting off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by patrickmaher, Mar 26, 2006.
  1. patrickmaher
    patrickmaher New Member
    Kauai, Hawaii, USA
    I'm taking my Prius in on monday to have it looked at but I figured I would ask here and see if anyone has had this problem.
    My girlfriend was filing gas and the gas pump kept shutting off. It shuts off almost instantly after you start filling and each time you pull the lever it just keeps shutting off. She switched to a different pump and was able to fill up the rest of the tank no problem. So we figured it was the pump.
    A few weeks later I go to fill up the tank at a different gas station with 2 bars left on the fuel gauge. I start to pump gas and it clicks off almost instantly. I try again and it keeps happening. I make sure to only pull the lever slightly in hopes of getting a slow gas flow, but it still shuts off. I asked my girlfriend who was with me at the time to try. She tries and gets the same result. So we ask her dad who was with us at the time. This is our first car and have had it for less than a year so we figure maybe he knows something we don't. Well it still keeps shutting off for him. He eventually gets it going by pulling out the nozzle a bit. I assume it was working with the nozzle pulled out a bit because the shut off is being defeated. I say this because the pump never shut off and gas came spewing out and continued to slowly dribble out for quite a while.
    We hoped that we just got unlucky with 2 pumps at 2 different stations. I figured since my girlfriend had luck switching pumps the first time we had this problem that it had to be the pump causing the problem.
    We eventually had to fill up again and we made sure to go to yet a different station. The same exact problem happened.
    Has anyone heard of this problem before? What could cause this?
    Thanks
  2. priusblue
    priusblue New Member
    152
    I haven't had any problems with the pump not filling at all, but I have had troubles with over/under filling, and it's highly pump-variable. From your description, it sounds like a pump-specific problem, but related to the bladder. You were probably just getting an air lock and the pump couldn't deal with it. My advice would be 1) don't use those specific pumps again and 2) if you have this problem again, try ensuring that there is a gap for pressure balance and try filling as slowly as possible at first. Once you get it filling make sure that you gradually push the nozzle down so that you don't have spillage. If that makes it cut off, just put in less gas than you possibly could have used (4-5 gal or so) and use a different pump next time.
  3. storm petrol
    storm petrol Member
    106
    17
    44 degrees, 42 minutes North; 73 degrees, 29 minu
    Hello, priusblue,
    There are many threads on this site that address this problem. It sounds like you have a Gen II ('04 or '05), yes?
    I have the same generation and the same tendency to have difficulty with filling. I find myself seeking out the older, slower gas pumps, which alleviate the problem. The theory is that the bladder that lines the tank is somehow responsible for this. Theoretically, the bladder expands slightly under the pressure generated by too-rapid filling combined with inadequate venting. Then the tension from the expansion causes the bladder to 'exhale', thereby shutting off the pump. If quite full it may also exhale fuel!
    Your manual will tell you that the volume in the tank will vary considerably with temperature due to the bladder. The volume decreases with decreasing temperature.
    Enough people have had difficulty with this that a Technical Service Bulletin (TSB) was issued by Toyota to correct it. I think the main goal of the service was to address peoples difficulty filling the gas tank. A TSB is not a recall. You generally have to initiate the servicing by requesting it, but it is free of charge. If you use the Search function (upper right of the page) and put in "Gas Tank TSB" you should be able to get the specific info. This would include whether you VIN is covered by the TSB. I think the work was fairly extensive, involving replacing the filler neck and re-flashing the appropriate ECU.
    My VIN was not included, so having this done was not an option.
    Good luck,
    storm petrol
  4. storm petrol
    storm petrol Member
    106
    17
    Sorry, priusblue!
    I meant to be addressing patrickmaher.
    storm petrol
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    it is VERY important that you keep a tight seal while filling your tank. otherwise, you will greatly increase your chances of spilling gas. to me, it sounds like its a pump problem.
    you say you are able to fill the tank successfully on occasion. that tells me that there is mostly likely nothing wrong with the car.
    i blogged a post on this with a detailed explanation from an expert gas pump jockey sort of dude. actually, he is a professor at scme college...but he sounds like he knows what he is talking about and pumps need that tight seal to work correctly.
  6. c4
    c4 Active Member
    607
    51
    *None* of my previous vehicles have ever had a tight seal on the filler and they all worked perfectly with every single nozzle.. The Prius *does* have a tight seal and is a pain in the butt to fill up sometimes.. Hmm.. I think the professor has a disconnect between theory and practice...
    I've found that only putting in the very tip of the nozzle increases the chances of an easy fill, but every time I fill up, I still think seriously about taking an X-acto knife to that rubber gasket around the filler opening, which would make the car like every other car out there except for the variability of the bladder, but I believe you should be able to get a truly "full" tank consistently without the gasket. Yes, fill-up emissions could potentially increase, but use of vapor-recovery nozzles should take care of that..
  7. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    that gasket is to help prevent splash back
  8. richard schumacher
    7,666
    1,047
    United States
    Lots of gas pumps are not well maintained. Can you just keep using the one you found that works well?
  9. jrfaris
    jrfaris Member
    352
    Windward Oahu
    Copied the following from a post made not too long ago. The original discussion was on the old version of PriusChat. See this post
    "As indicated there are some previous posts on this subject. I believe this is different than the cold bladder problem that may reduce the volume of a complete fill up. There are two suggestions that I recall. One was to lift the hose to be sure the vapor recovery portion did not contain overfill from the previous user. Supposedly, lifting the hose drains any residual gas that might cause early shut off. The second was to turn the nozzle over while filling. I have had this problem occur exactly twice in about 18 months. The first time I was clueless and just spent 10-15 minutes to short pump 6 gallons in an empty tank. The second time, I did both of the above and was able to fill the tank without further problem (except struggling to keep the nozzle inverted). I haven't had the problem for quite some time so maybe bladder seal in the fill tube loosens over time, reducing the problem"
  10. patrickmaher
    Kauai, Hawaii, USA
    Thanks for all your quick replys.
    I have filled gas 13 times on my car so far. The first 10 times I have not had a problem and they were at various stations on various pumps. I have never had this problem in my first 10 fill ups. Now suddenly 3 fill ups in a row at 3 different stations I have this problem. I have been to all 3 of these stations in the past with no problem.
    Now it could be that I was lucky the first 10 times and had really bad luck the most recent 3 fill ups, but that seemed unlikely to me. The symptoms were exactly the same and consistent.
    storm petrol I will take a look for the Gas Tank TSB, thanks.
    We stood there filling for awhile, trying different things. We tried a tight seal, a less tight seal, pulled far enough back to avoid the shut off detection. The only thing that worked was defeating the shut off. I'm guessing it would take like 20+ minutes to fill up, If I pumped normally and kept pulling again whenever it shuts off, of course I wouldn't know when it is the real shut off.
    To recap, I have not had this problem at all before now. Only the most recent 3 times have had this problem. 3 different stations, consistently get the exact same symptoms. I understand and hope that it could be 3 bad pumps but I doubt it.
    Thanks,
    Patrick
  11. descolline
    descolline New Member
    I have the same problem. 07 model. I did not have the problem during first winter, but this year two fill-up & both times I had to fill very, very slowly. I am in northern NM & it seems to be worse when the weather is cold.
  12. Gwydion
    Gwydion New Member
    Ottawa
    I have the same issue on my '08 purchased this summer. Sometimes everything works fine, but at others pumping stops immediately. I find if I pull out the nozzle a little bit (not too much) I can pump freely and autostop still works.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    This has been discussed forever here. I have learned with my 07 to let it air out a little before fueling after my first gas belching episode. The zero fuel vapor emissions mission and the fuel recovery system on this car coupled with the plastic bladder has made this car very hard to fuel. Try this and you will have no more problems:
    When you go to the gas station open the gas fuel cap. Leave it open without the gas pump in it and go inside for a bit. Those few minutes of tank venting will allow the tank to breath and expel trapped air and allow the bladder to relax. By the time you come out it will be good to go. Stick the pump in it on very slow fill and hang the pump up on the first auto click off and your fueling troubles will be over. I have cut a piece of wood 1/2 inch wide to jam under the pump handle which pumps very slow. It now clicks off on a full tank first click. Perfect.
  14. PaulTomblin
    PaulTomblin Junior Member
    Rochester, NY
    I got my Prius this September. So far I've only had to fill it up 9 times, and until yesterday every time but one I've had this problem with the first gallon or two, but then it would settle down and I could fill normally. But yesterday's fill up was an exercise in frustration and anger - it would only pump for a second without shutting off no matter how slowly I filled. It's the first time I've filled it up in below freezing temperatures, so I wonder if that is the problem.
    I tried various combinations of pumping very slowly with the nozzle fully in, partly out, twisted to one side or the other. I even tried pumping with the nozzle not through the restrictor at all, and the gas was going down through the hole at first but after a second a big slug of gas came shooting out. All in all, I spent about 15 minutes at one gas station getting ~4.5 gallons, and then another 15 minutes at another station getting another ~4 gallons.
    Every other car I've owned, including two Corollas, has had a hole in that restrictor plate for air to come back out. I assume that the Prius supposedly doesn't need it because of this flexible bladder people have been talking about in this thread.
    My wife's 2005 Prius doesn't have this problem. Is is possible that my car's bladder isn't flexible enough?
  15. deetee
    deetee New Member
    Knoxville, TN
    YOU MAY HAVE SUGAR IN YOUR GAS TANK!!! I just found this out because my car did the exact same thing yours did. I took it to the shop because my car kept stalling. See if someone will take a look at it for you. It may cost you about $100-$200 to fix it.
  16. qbee42
    qbee42 My other car is a boat
    18,058
    3,080
    Northern Michigan
    This thread is about filling issues, not stalling engines.
    Tom
