Gas tank capacity
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by alfon, Dec 9, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I noticed that our Prius when the pump clicks off at slow speed setting I can
    still put in another 2 gallons of gas with gas at that point showing at the filler
    neck. I know, I know, this is forbidden buy most owners, but I am just
    trying to see if the Plug in Prius as the same type of gas tank that allows
    another 2 gallons of gas to be put in after the pump stops.
    51,140
    mine is pretty close to full at the first click. are you saying you can see the fuel in the filler neck, and yet you can still add two gallons?:confused:
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    oops....almost time for me to put gas in my PIP since July 26, 2012, another gallon to go , need to put at least 7.5 gallons in (based on BP gift card of $25.00 and gas at $3.39/gal.):D
  4. n5160u
    n5160u Junior Member
    22
    17
    The reason you can still put gas in it is because all closed system gas tanks have extra space reserved for the fuel to expand into when the fuel gets warmer as in hot weather. If you intentionally overfill the tank there is no place for the extra volume of fuel to go and in older non zero emission certified cars the over flow fuel and vapor went through a charcoal filter to treat the vapor and extra fuel went into a cannister to be burned later which led some cars to overheat their catalysts under those conditions..
    The zero emissions system is really closed on our cars so I don't know how it deals with the excess fuel volume from expansion, but I am sure overfilling could damage the emission equipment it it finds an excessive volume of fuel beyond its design limits
    lensovet likes this.
  5. Vern2
    Vern2 Junior Member
    50
    Arizona
    2014 Chevy Volt
    Ever wonder what those little holes are at the end of the nozzle?
    Problem is the law has changed in most states, for gas stations to install vapor recover systems at every pump. What that means as you fill the tank, the pump nozzle is vacuuming off the vapors. The problem is you keep clicking the nozzle the vapor recovery system is sucking raw gas from the top of your filler stand pipe. The gas station owner lovers it. Your paying for gas that is going back into his underground tanks.
    WHEN THE NOZZLE CLICKS OFF STOP FILLING YOUR TANK
    xpcman and priuskitty like this.
  6. El Dobro
    El Dobro A Member
    7,075
    3,258
    With the PIP, you're not doing a fill-up. When you hit the filler door release, you're doing a fill-up request and are suppose to wait until the car gives the ok because the EVAP system is preparing the car to accept the fuel. This may be the reason why the PIP takes on less fuel than the regular GenIII. It may not be a good idea to top off.
  7. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    The tank is physically smaller.
    Why carry so much fuel knowing it could be several weeks before refilling again?
    At 20,000 miles per year and usually recharging at home & work, it provides me with a 10-day supply. I see no need to risk damage to the evaporative emission system by squeezing more into the tank or to go any further. Distance wise, it works out to roughly 550 miles in the winter and 700 miles in the summer. That's plenty long.
  8. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    The plug in Prius has a 10.6 gallon tank compared to the 11.9 gallon tank found in the Prius lift back.
    I know you can fit in more after the pump clicks off, but I never measured how much. I know I have done maybe a gallon but to keep clicking to fit 2 gallons takes more time than I would want to stand there. Not to mention fitting in that much just, to me, would not make sense.
  9. retired4999
    2,652
    625
    Eau Claire, Wi.
    I agree, I always fill to the next even gallon, never any problems. Just makes it easier to figure mpg if always a even gallon. :)
  10. bisco
    51,140
    i used to fill to the next even dollar amount, but it moves so dast at today's price's, it's difficult to stop on the penny.
  11. retired4999
    2,652
    625
    Eau Claire, Wi.
    True, I use the same pump all the time and you get kind of now how it works, makes it easier to judge! not perfect but close! :)
  12. Mendel Leisk
    40,574
    Since this seems to be a poll:
    I stop when it first shuts off. Make no attempt to top up or round off.
    Get the receipt.
    Write the odometer mileage number on the receipt.
    Also note Trip A mileage and displayed liters/100km on the receipt, then reset Trip A (Just for insurance, the odometer mileage number is my mainstay.)
    Enter into a spreadsheet: the odometer reading and amount of gas. Also, just for laughs, enter the Trip A displayed liters/100km, to track the TBP (Toyota BS Percentage).
    WilDavis likes this.
  13. bisco
    51,140
    there are so many things to record and reset after filling, i have to pull away from the pump and park for a few minutes. last time, i was there so long, the owner came over and asked if i was okay. probably thought i was having a heart attack or something.:eek:
    my reflexes have slowed waaaaaaaay down.(n)
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    +1 :ROFLMAO:
  15. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I can drive my car to where it says "0" in the range meter ... like "no more driving" and I cannot get it to take more than 8.5 gallons, ever!
    retired4999 likes this.
  16. bisco
    51,140
    nah, you can drive another hundred miles, trust me!:D
  17. lensovet
    2,615
    496
    Burlington, NJ
    Really wish the tank was bigger so I could do my LA to SF trips without stopping…
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it's 381 miles, isn't tank to empty 550 miles? mine is:D
  19. lensovet
    2,615
    496
    Burlington, NJ
    See my other post! Not 550 when you're going 80 mph :-(
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    can't hep u der lol:p
