Gas Tank Caps: Sprayed with gas using add-on no-remove gas cap
Discussion in 'Gen 2 Prius Main Forum' started by DuPrius2008, Oct 31, 2012.
  1. DuPrius2008
    DuPrius2008 New Member
    Recently purchased 'thru gas cap fill cap ' that replaces original gas cap on my gen II 2008 Prius. First couple of fills were ok.
    Only slight movement to get filler nozzle thru both the gas cap hole and the original fill hole.
    On subsequent fill when tank was almost empty, there was sudden pressurized spray from fill cap while I was still squeezing the gas nozzle. Gas hit me in face and shirt.
    I wouldn't want this to happen again so I put original gas cap back on and tossed the no-remove gas cap.
    usnavystgc likes this.
  2. DuPrius2008
    I think the bladder is involved in this spray back, because spray continued after releasing fill lever.
  3. usnavystgc
    3,159
    989
    Tucson, AZ
    Appreciate you sharing that w/ us. Def wouldn't want that to happen to the wife.
  4. Mike500
    Mike500 Senior Member
    2,593
    764
    The gas cap is part of the Fuel Evap system. If it leaks, it will show up as an error as a Check Engine light and an OBDII error code.
