Gas tank half full pros/cons?
Discussion in 'Prime Main Forum (2017-2022)' started by Marine Ray, May 2, 2019.
  1. Marine Ray
    Marine Ray Senior Member
    1,139
    941
    Sparks, NV
    With so many Prime group members pleased (myself included) to rarely having to go to the gas station , what are the pros/cons of keeping your gas tank at half full unless you're on a long trip ?
  2. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    pro: battery has to push less weight tf more milage.
    pro: sending less money at fuel station
    con: you will be at the station twice as much
    Mark57 and Tideland Prius like this.
  3. Marine Ray
    1,139
    941
    Sparks, NV
    So about 30 pounds of weight (6 pounds/gallon x 5 gallons)?
  4. will the engineer
    238
    119
    LA
    2019 Prius Prime
    idk I never looked up the weight of fuel before. But when I drive around down to the second to last tick mark.
    I noticed I am able to drive much further on EV. its not an energy dense source. so it responds well with weight reduction
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    That is spending less money at a time, not less money. Sort of like paying your taxes in 10 parts - you still owe the same amount...
    will the engineer likes this.
  6. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Yes. You could save almost half this weight by removing the owner's manual from the glove box...:)
    Went to the kitchen and checked. The owner manual alone is 1.62 lb, the nav manual is another 0.65 lbs.
    benagi, walterm and bruceha_2000 like this.
  7. will the engineer
    238
    119
    LA
    2019 Prius Prime
    good catch!
  8. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    301
    Northwest VT
    2018 Prius Prime
    But without the installment fees. At the moment, with gas going up pretty quick, it might be a good time to fill the tank thus putting off some expense. You can always reduce weight in the car in other ways. Like have the kids run alongside ;)
    KCWhitney and benagi like this.
  9. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i'm only adding 5 gallons when i need to fill up. i dont travel anywhere where there isnt a gas station every few miles.
    tank is sealed and pressurized to keep out moisture. the 5 gallons will take less time to burn off and refresh.
    i havent had the car long enough, but i fill up so infrequently i dont mind if its once a month or once every two months:)
    bisco, jb in NE and Marine Ray like this.
  10. bruceha_2000
    3,054
    301
    Northwest VT
    2018 Prius Prime
    With my regular driving habits, I'll be going to the gas station to get gas for the riding mower a lot more often than to put gas in the car. Different station for the unadulterated gas for the string trimmer and chain saws and yet another for off road diesel for the tractor.
    Marine Ray likes this.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    We just had another one of those "accidental fire incidents" at the local refinery down here in SoCal. $4 per gallon ain't enough? Create a fire!
  12. fuzzy1
    10,164
    I don't follow. For the folks who rarely burn fuel and are at risk of it going stale (apart from the controversy about whether or not it even goes stale in these better-sealed tanks), a partial tanks means less fuel to go bad, or to be burned off preemptively. Or less to be diluted with fresh fuel on a fixed calendar refresh schedule.
    These 'twice as many station visits' arguments would apply only to those who burn more significant amounts of fuel, closer to non-plugin cars than to electric-only cars. We have many Prime owners falling on each side of this divide.
  13. Marine Ray
    1,139
    941
    Sparks, NV
    Hmm...adding the weights of only half a tank of gas plus manuals means I can gain about 33 pounds and still get the same MPGe. Buffet here I come.
    It'd be nice if would could bring up the manuals on the 11.6 inch screen.
    #13 Marine Ray, May 2, 2019
  14. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    My point was that you don't save money by putting in less gas at a time. You burn what you burn, and replacing it costs the same whether you replace it all at once or in increments.
    I keep mine sync'd to a DropBox account, which is sync'd to Goodreader on my iPad. When I travel, all the manuals are on my iPad, and not in the glove box.
    That's a good strategy. At the end of my upcoming long trip, I may not fill the tank when I get home. Half full may make more sense.
    #14 jb in NE, May 2, 2019
  15. Tideland Prius
    16,128
    That’s not insignificant. That’s almost two Gen 3 alloy rims
    Given the smaller glovebox, I opted to leave the paper manuals at home. I have the PDFs on my phone.
    benagi, Marine Ray and fuzzy1 like this.
  16. fuzzy1
    10,164
    My point is, that is the view as seem from a regular gasser. It doesn't necessary apply to PHEVs that burn so little gas, that the car or driver needs to take actions to deal with gas that is getting too old.
    Tideland Prius and Marine Ray like this.
  17. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    For me, with 25 miles EV range, and ~40miles/day commute, I use up a full tank in 4-8 weeks, depending on how much out of EV range drive outside of my daily commute I do. There is no pro in filling only half of the tank at a time.
    I am such a pessimist, I see a half-full tank as a half-empty tank. lol
  18. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    All true, but none of that changes the cost. Unless price changes work in your favor.
  19. jb in NE
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I "topped off" my tank today in preps for a road trip, where I want maximum range. 1.53 gals and I drove the car 1063 miles since 2/26/2019. For my driving habits, I could easily have started with 1/2 tank and not hauled around the extra 5 gals of fuel for 2 months.
  20. fuzzy1
    10,164
    Yes it does, if one is needing to burn off old gas because of its age, when one would otherwise be sticking to EV driving.
    I won't be getting into this situation, but it seems that numerous Prime drivers already are.
