Gas Tank Size
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SanteePrius, Jan 25, 2010.
  1. SanteePrius
    SanteePrius Junior Member
    Santee, Ca
    I have a 2010 Prius V... Today I waited till the fuel gauge was flashing the last little pip and my miles to empty said 0 (I was actually 20 miles past that point).
    When I filled up the pump only read 9.1 gallons - I was able to stand and nurse it up to 11.1 but what size tank does this thing really have...
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The fuel gauge reading empty does not mean that the tank is really empty. The only way to know that the tank is empty is to run out of gas, and even then there is some unusable fuel in the bottom of the tank.
    The gross capacity of your tank is 11.9 gallons. Usable will be slightly less than that, but close on the Gen III.
    Tom
  3. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    There are threads about this ongoing, that it is typical when the flashing starts to have about 2.1 gallons left.
    The tank is 11.9 gallons as Tom mentioned. It is a regular tank now, compared to the 'bladder' tank that the Gen II had in the US.
  4. PazPrius
    PazPrius New Member
    72
    San Diego
    Wow that's good to know, so no need to panic since these don't seem to run on EV without the ice.
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Uh, yes they do, the difference is they don't warn you.
