Gasket Masters: Recommended or Not?
Discussion in 'Gen 3 Prius Main Forum' started by JJGriffith, Aug 4, 2022.
  1. JJGriffith
    JJGriffith New Member
    Cleveland, Ohio
    I have a 2011 Prius, high mileage and bad head gasket. Looking to do an engine swap. Not many options in Ohio beyond dealerships and I don't really want a junkyard engine for $7,000. Car's not worth it. I understand Gasket Masters comes to the Midwest once in a while and swaps engines. I know their videos are great and their reviews are mostly good but there are also reviews that concern me. Anyone have experience with them? Trustworthy? If you don't like them, do you know of other companies that do similar work? Thanks!
  2. Krall
    Krall Member
    125
    37
    NY
    I can’t comment on those guys, but that price for a used engine seems nuts. Most of the ones I’ve looked at 70k and under $1700. There’s a company on Craigslist and eBay called JDM that seems legit and sells them for a reasonable amount.
    JJGriffith likes this.
  3. Mendel Leisk
    42,062
    My one interaction with them: they had a video on replacing pcv valve on a third gen. They took off the intake manifold for access. I put a comment that that was a good approach if you wanted to clean the intake manifold, but just for pcv valve access you could reach it from below, without the need to remove the intake. I made a point of wording it very tactfully, at least I thought so, but the main guy came down on me like a ton of bricks, very insulting/disparaging.
    In one of their videos, a protracted, no explanation, just fly-on-the-wall view of that main guy doing a head gasket, he gets a phone call, apparently from a previous customer. It doesn't go well and he starts cussing out the customer. And this is one of their promotional videos.
    Xterra72, Merkey, mikey_t and 3 others like this.
    52,558
    i want to see that!:p
    JJGriffith, mikey_t and Krall like this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,713
    6,727
    Texas Hill Country
    $7k should buy you a rebuilt engine installed. Starting with a lower mile used engine probably is better than your engine which may not have rebuildable cylinders.
    "The Car Care Nut" has a recent video of a rebuild with a new short block for similar dollars. He is in the Chicago area and was a Master Toyota mechanic at a dealer until this year.
    In the end, Gasketmasters will likely cost less but you need to know what they consider a rebuild. New rings and a machined head with new valve seals would be my minimum.
    Any rebuild should clean the intake, egr cooler, throttle body and use all new gaskets with a guarantee of 90 days or better. A year would be my minimum. I would supply a new intake, quality oil catch can and radiator fan assembly for my rebuild.
    kitty_tron and JJGriffith like this.
  6. mikey_t
    mikey_t Active Member
    371
    391
    Los Angeles
    Woah! Major red flags. Not just picking fights in the comments section (LOL) but not having the mental wherewithal to edit a video of the boss taking a call and yelling at a customer before posting it to the internet to advertise the business. No thank you.
    Merkey likes this.
  7. Bill Norton
    Bill Norton Senior Member
    2,225
    746
    MONW, Ks.
    2019 Prius
    L Eco
    A used engine gets you a used head gasket.
    A chronically failing head gasket.
