Gasket/washer part number inverter coolant drain plug
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priuscooker, Jan 5, 2019.
  1. Priuscooker
    Priuscooker Junior Member
    DF-Dub Texas
    I have searched the forum and ask ed the dealer but have come up short. Does anyone know the part number for a gen 2 gasket/crush washer for the inverter coolant drain plug on the trans axle. Is it the same as the trans axle fluid drain and fill plug. which is 90430-A0003 (this replaces 90430-18008). It appears that the coolant drain and the trans axle fluid fill bolts are 24mm, same size.
    Seems like a few people have asked the question and no one has posted a definitive answer.
    #1 Priuscooker, Jan 5, 2019
    ydpplqbd, Inspire3 and donbright like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    The aluminum crush washer is the same for all;).
    They even work in the Gen3 as well as a Lexus RX450h if you were curious:).
    I buy them by the dozen (y).
    Inspire3 and JC91006 like this.
  3. Priuscooker
    DF-Dub Texas
    Thanks for the reply
    Raytheeagle likes this.
  4. TPolo
    TPolo Junior Member
    Denver, CO
    Would you please link where you get them exactly? Thanks!
  5. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Search oil drain plug washer on Amazon;).
    Good luck and keep us posted (y).
  6. Mendel Leisk
    38,653
    Dealership parts department will know. Pick it up with the oil filter?
