gasoline and battery life
Discussion in 'Newbie Forum' started by pluvius3, Nov 19, 2010.
  1. pluvius3
    pluvius3 New Member
    Stony Brook, NY
    My daughter recently experienced a dead battery which she was told by the technician was a result of letting her gasoline go down to one bar. The warning light had not gone on so the tank was not really close to empty.
    52,404
    what year is it? how many miles? probably a result of that. never heard of the low fuel thingy. find a new tech!;)
  3. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    You should go ask that tech if you leave your lights on too long will you run out of gas?
    Technician my arse :D
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    Get a better technician. This one is full of it.
    Tom
  5. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Going down to one bar is about 2 gallons left (give or take). If it's in ready mode (running) the battery will drain down turning on the gasoline engine and charging then turning off the gasoline engine. This cycle will go until you run out of gas (in a day).
    If the car is not in ready mode you will not use any gas.
    Technician is full of bunk as said by everyone above.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Let me guess. The technician's name was Larry because he's "pretty smart for an imbecile".
    Trickle charge the battery then use Diagnostic Mode on the MFD to check the voltages.
  7. richard schumacher
    7,666
    1,047
    United States
  8. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Most of the PCers will recommend filling up at 2 bars. IF: the car actually runs out of gas and the driver continues to drive on the HV serious problems can ensue. Best thing is to fill up early. :cheer2: There are reasons for a dead battery (12V or HV) you didn't say. One bar on the gas guage is not one of them. Is the car being repaired?
