Gasoline octane rating question
Discussion in 'Gen 2 Prius Fuel Economy' started by cap_ut, Nov 30, 2005.
  1. cap_ut
    cap_ut New Member
    25
    In the manual it states that one should use regular 87 octance gasoline. Where I live, Salt Lake City, UT, regular gasoline is 85 octane. Will this be a problem? Should I go with the 87?
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    At higher altitudes cars require a lower octane than at sea level. (Less air, lower air pressure, lower pressure in the cylinders) In the front range of Colorado all you see for regular is 85. Same in SLC. At your altitude it works like 87 at sea level.
  3. aaf709
    3,862
    2022 Prius Prime
    Comsumer Reports once did an article about the wastefulness of using a higher octane than needed. They suggesting trying a lower octane than required. If there's no problem (knocking or pinging) then use the lower. For example if a car's manual says 94 try 90. If 90s too low try 92. In your case, you shouldn't have any problems, but if you do try 87.
  4. MarkR
    MarkR New Member
    Tried this. Filled it up with Premium ULP and got better milage (.3l/100k) but it was still cheaper to run on STD ULP!
  5. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    narf is right.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Octane rating is not about energy/gallon it is about premature ignition with compression. Do a search and you will find multiple threads on this subject. When all variables are eliminated high octane gas provides lower M.P.G. than the one appropriate for the car.
