Gasoline vs. Electric motor
Discussion in 'Gen 3 Prius Fuel Economy' started by wanaset, Aug 30, 2012.
  1. wanaset
    wanaset Junior Member
    86
    16
    My commute is around ~45 miles from my house and I travel at an average speed of 20 MPH. The reason I do not take the freeway is because it would take longer due to traffic. I just hate bumper to bumper traffic. The problem is that since I travel at such a low speed, I am mostly using the electric motor. My battery goes down to 2 bars before I come to a stop and recharge it. Throughout my commute I rarely use the ICU engine, mostly on complete stops.
    Many members on priuschat have argued that you wear out the traction battery by overusing it. Would it be in my best interest to stay on the right of the HSI indicator? This would mean that my car is using both the ICU and the electric motor. When is beneficial to use the electric motor only?
  2. Munpot42
    Munpot42 Senior Member
    1,391
    543
    Santa Monica, Ca. 90405
    Just let the cars computers do the thinking, they will protect the traction battery.
  3. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Are you attempting to force battery use? If that is the case, then just change the screen view and drive as if you don't know there is anything other than an IDE under the hood. See if that changes anything.
    For what it's worth, though, I rarely move from the HSI screen, as it gives me very good and immediate feedback in terms of fuel economy and "stealth" driving. I never worry about whether the battery has six/seven bars or just two, as I know the computer is monitoring everything and will protect the HV battery.
  4. fuzzy1
    10,173
    At that low average speed, I don't think you have much choice. Once the ICE is warmed, the car is going to heavily favor electric mode, and the battery level will tend to hover near 2 bars.
    As a_priori hinted, don't attempt to force electric mode, just drive naturally and let the car make its own choice. If you want to 'force' different operation, I'd suggest trying a traffic-matched Pulse & Glide, pushing the HSI bar to the right and turning on the ICE during the pulses, if you can make it fit traffic conditions and if you can achieve a better round trip MPG than just driving naturally. But if you can't find a pattern that works, or it if takes too much work and attention, or if the resulting MPG doesn't increase, or if the ICE pulses lead to increased braking (regenerative braking is still lossy), then go back to driving 'naturally'.
    What MPG are you getting now? What is your approximate location? Outside temperature?
  5. wanaset
    86
    16
    Thank you for all the great responses. I live around Santa Monica and the average temperature for this month has been 75F+. In order to solve this issue I need to turn off the HSI monitor since I do force the car into electric mode every time I leave from a complete stop. It has become more of a game now, I get around 65MPG+ on average and the best trip was at 79MPG. Regarding the speed, I can actually travel faster since the speed limit is 45MPH, but I rarely exceed 37MPH unless I have people behind me. Would it be in my best interest to travel around 45MPH in order to use both the ICE and electric motor?
    It does make sense not to discharge and recharge the battery on every stop.
  6. a priori
    3,083
    407
    23
    Chicagoland (West)
    I think you may find the mileage will be very good traveling at 45 mph. There are times to use just the battery, but I think they are rather infrequent and occur only when you are trying to avoid having the ICE on for a very short time with no need to really increase speed. For the most part, the better fuel economy comes from getting up to speed and letting the terrain and traffic guide you -- gather more speed going downhill and bleed it off going uphill. Anticipate stoplight changes. Don't clog traffic.
    I'd also lower the windows and soak in some of that sea aroma. It will lower your MPGs but increase your enjoyment.
  7. fuzzy1
    10,173
    Once the engine is warm, it should shut off naturally at stops and during glides, without you having to force it. Then, while you are stationary, the engine ought to stay off until the car decides the battery is too low and needs recharging, or the coolant gets too cool.
    One of the goals of traffic-matched P&G is to do the battery recharging during the Pulse phase, so the engine doesn't need to fire up while you are stopped. However ...
    You are already doing quite well. I don't know if there is much room for improvement without a ride-along from an expert such as Wayne Gerdes, who'll push for 86 mpg.
    You should be using the ICE in the pulse or acceleration phase even below 45 mph, for both propulsion and for battery recharging. Save the electric for the lowest speeds, and to extend glides after reaching travel speed on the ICE. If you keep speeds below 45, then the ICE will quickly shut off when you back off on the gas pedal, for most efficient gliding.
    At and above 45, the ICE must still spin even when it quits burning fuel, which makes for a bit less glide efficiency. And in Gen3, this spin can be a bit sticky -- as you slow down below 45, the transition from 992 RPM to 0 RPM can be significantly delayed while the car waits to make sure you aren't soon speeding back up. If you never get up to 45 mpg, this stickiness doesn't happen.
    And keep watching the daily round trip MPG. I believe friendliest battery use should align fairly well with high MPG. If MPG falls, go back to your old style.
  8. walter Lee
    1,126
    376
    Maryland
    Its always better to avoid relying on the electric motor.
    You can minimize your reliance on the electric motor
    if you set the Prius throttle to Normal or Power mode.
    and if you do mini-Pulse and Glides.
    In a mini Pulse and Glide you are going at lower than normal speeds
    for shorter time periods
    Say you are on a very flat smooth road surface ....
    You are at a dead stop at stop sign ,
    Press the accelerator lightly never going pass 1/4 of the ECO bar
    build up speed to 5mph to 10mph on electric
    ( this is to eliminate initial inertial forces),
    then
    (start mini- P&G cycle)
    press the accelerator down very fast so
    the HSI display is past the 1/2 "ECO" marker on the top
    to start the ICE -- the HSI indicator should be slightly past the "C" of the "ECO" marker
    until you reach your target max speed (e.g. 18 mph),
    then let go of the accelerator so that the HSI indicator is
    now on the far left side of the ECO bar
    (and the gas engine automatically turns off and the electric motors are off or bearly running)
    but regenerative braking is not occuring
    Glide until the Prius speed drops down to your target low speed(e.g. 12 mph)
    (repeat mini-P&G cycle)
    you target max and low speed are based on the traffic you need to work with.
  9. wanaset
    86
    16
    Thank you for all the great information. I will try the "mini-P&G" cycle tomorrow. I have a quick question about it - Should I be pressing the gas pedal while I am in glide? I have watched a youtube video where the individual stated that you should be pressing the gas pedal with very little force. The issue I have with this is that since I am traveling at such a low speed, I will force the electric motor to come on. On the freeway it is understandable to press the gas pedal with very little force in order to maintain the speed. Regarding the traction battery - does anyone ever use the battery to the point where only 2 bars are left?
  10. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    Looking at the HSI, press just enough to remove the regen drag, so that no power or regen is indicated. This is a glide.
  11. a priori
    3,083
    407
    23
    Chicagoland (West)
    You will not be in a glide unless you are pressing the accelerator pedal, ever so slightly. If you let off the accelerator, you will be coasting in a mode that Toyota designed to emulate an automatic transmission. The ICE doesn't cause drag, but the one electric motor will be dragging (I believe it works that way). By depressing the pedal, you can cause the other electric motor to counter the spin of the former and produce, effectively, a neutral drive position. This is the glide you seek, and you can see it, more or less, on the HSI screen. It is when there are no bars evident: none to the left (which would be regen) and none to the right (which would be power output).
    This happens on a regular basis. So does six bars. Don't let it bother you, unless that is all you ever see. If it is, then you likely are relying too much on the electric drive, meaning you have to be using the ICE to generate power to be stored in the battery. This is an inefficiency you want to avoid more often than create.
  12. wanaset
    86
    16
    Thank you for the detailed explanation. I have a much better understanding how to efficiently drive the car. My issue was that I kept forcing the electric motor when I should have allowed the car to do it self. I will report back tomorrow after my commute.
  13. a priori
    3,083
    407
    23
    Chicagoland (West)
    It sounds like you are pretty far along on the learning curve already. Enjoy!
  14. walter Lee
    1,126
    376
    Maryland
    When only 2 bars are left on the HSI SoC gauge (about 40%-45%) the Prius will automatically restart the ICE and recharge the HV battery back up to 50% (usually four bars). If the Prius is standing still (at a stop) while it is automatically recharging the HV battery that trip's FE tends to drop about 5 to 8 MPG. The only time the Prius gas engine will not recharge the HV battery is when the Prius is out of gas - at which point the Prius will run on electric power only until the HV battery is fully drained - which is a very very very very bad thing. If the Prius HV battery is drained to zilch - the Prius will need to be towed to the dealership to recharge the HV battery before it can use gasoline again. The Toyota dealership will likely be the only place you can recharge the Prius HV battery. One cannot jump start the Prius via 12vdc aux battery with a dead HV battery because the 12 vdc aux battery does not power the starter motor. The HV battery powers the starter so when the HV battery is fully discharged - the Prius will be unable to start up regardless of whether it has gas or not. Draining the HV battery to zilch will also shorten the lifespan of the HV battery as well. At least that's how I understand the mechanicals.
  15. fuzzy1
    10,173
    If you are maintaining a constant speed on a level road, the HSI bar should not vanish as it does in a true glide. If it really vanishes, then either the road has some downslope, or car car is gradually slowing.
    It is common in stop-and-crawl traffic, and is normal in such situations unless one makes a special effort to avoid it. On free flowing roads, it is rare unless one is forcing electric mode for some reason.
  16. austingreen
    austingreen Senior Member
    13,576
    4,114
    Austin, TX, USA
    No not really. If you can go 45 mph, and trafic is fine with you at 35 mph, pulse and gliding between the two, or maybe up to 42 and down to 35 might use less gas, and actually save time. If you have juice in the battery accelerating to 10 mph on battery may make sense, but if your at 2 bars, go ahead and giver it a little gas. You are much more fortunate in route to get 65 mpg+. Let us know if you like the pulse/glide game and if i gets your mileage even higher.
    On a glide you do want to press on the accelerator until the their is no charge or discharge on the hsi. That is close to neutral and the engine will turn off at your speed, but not waste momentum by charging the battery. I often get to 2 bars, but I have hills and air conditioning. Traffic jams in the heat always get my battery low. If your battery is at 2 bars you may want to just go at a constant speed until it is charged up, instead of gliding down.
  17. wanaset
    86
    16
    Good morning,
    I tried all the tricks that I learned from this thread. The only issue that I had was watching the HSI indicator while keeping my eyes on the road. If I knew it was going to be that useful, I would have bought the Prius 4 with the HUD option. Anyone aware of aftermarket parts which would allow me to monitor when I am in glide? I might be jumping the gun as it probably takes a few days to get the feel when you are in glide. Nevertheless, I really enjoyed pulse and glide. It is a different kind of fun compared to my E92 M3.
    My MPG would have been better for the trip but I made far too many mistakes. I will try to improve on these when I am commuting home. One issue that I had was starting with a slow acceleration as I did not want to hold up traffic. On most lights I hit the power button in order to flow with traffic. The upside was that I made up for it while gliding down a hill. The best part about pulse and gliding is that my battery stayed full, before I was overusing it while forcing the electric motor.
    I have drove many cars before but this has to be one of my favorites. It keeps my mind off the long commute while I try to improve my MPG. It has become more of a game then actually saving money on gasoline. Now to convince my wife to get one , might be hard since she loves her car.:p
  18. Munpot42
    1,391
    543
    If you are already averaging 64 mpg, you really don't need much help, you're doing 20 mpg better than I and I also live in Santa Monica.
  19. wanaset
    86
    16
    Hey,
    My original intent with this thread was to find out information regarding the traction battery. Since my knowledge lacked on how the car uses the electric motor compared to the gasoline engine. This thread did inform me that I was overusing the traction battery by forcing the electric motor.
  20. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    After you do enough P&G cycles, it will become muscle memory/habit and you won't have to look at the HSI display nearly as much.
    Assuming you have long enough sections on your commute, I think feathering in a tad more throttle to get the indicator about 1/5th way into the EV side of the display will greatly extend glides while not eating up too much battery. YMMV (literally) :)
