Gauge brightness question
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by umichioe, Oct 22, 2012.
  1. umichioe
    umichioe Junior Member
    77
    Rain and fog season started. I found that the gauge brightness changes according the outside brightness even when the headlamp is in "ON" position. This seems to be annoying when the weather is cloudy. The gauge brightness changes frequently because sun comes in and out of the cloud.
    Can I make gauge brightness not changing with outside brightness? Now I am setting the auto-headlamp senstivity to low. Not sure if it will help or not.
    This is for Prius v Five with no ATP.
  2. tanasit
    tanasit Member
    399
    60
    Philadelphia
    I think if you roll the dimmer wheel all the way up (HIGH) pass the detent click, the gauge brightness will stay the same (on HIGH of course). Also see the post below:
    Dimmer switch revisited | PriusChat
