[GB] ’04-05 Prius Fog Light Replacement Bulbs
Discussion in 'Sponsored Commercial Sales' started by Areometer, Feb 21, 2005.
  1. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
    FYI: Your existing fog light stock color temp. = ±3,200K
    Click on images to enlarge & 4 Choices to choose from:
    [Broken External Image]:http://www.sigmaautomotive.com/polarg/polargimages/1specr-s.jpg
    POLARG Spec-R ‘HiR’ / 9006(HB4) / White (3800~4000K) / 55=120w
    Description: Halogen Infrared Reflective coating bulb that consumes 55w but outputs more than 2x the brightness of stock halogen. Color temperature resembles stock HID headlights found on Prius.
    MSRP: $124| PriusChat: $99/pair
    Regarding the above product:
    HIR (Halogen Infra Red) technology produces a brilliant white light that is double the intensity of other bulbs with the same wattage, with up to 72% Higher Lumens per watt. These bulbs represent the latest in lighting technology. A special reflective coating to the outer surface of an HIR bulb allows visible light to pass through while infra red light (not visible to the human eye) is reflected back onto the filament. This recycling effect superheats the filament thus increasing light intensity.
    Main features:
    • [Broken External Image]:http://www.sigmaautomotive.com/polarg/polargimages/1pureyellow-s.jpg
      POLARG Pure Yellow / 9006 (HB4) / 55=100w
      Description: Reduces glare under rainy, snowy & foggy weather conditions. Also, others spot you faster.
      MSRP: $82 | PriusChat: $62 /pair
      [Broken External Image]:http://www.sigmaautomotive.com/polarg/polargimages/1miraclewhite-s.jpg
      POLARG Miracle White / 9006 (HB4) / 4,300K / 55=100w
      Description: Color temperature resembles stock HID headlights found on Prius, so your fogs no longer look yellower than your HID headlights.
      MSRP: $84 | PriusChat: $64 /pair
      NOTE: S&H is extra. Within the US = $7 (UPS Ground) / Int’l = $22 (Global Express). Both methods include insurance + tracking info.
      How to order:
      1) Enter your info using our SSL order form
      2) Delivery: ± 2 – 3 weeks
      3) You will not be charged until product is in stock & ready to be shipped within 48 hours.
      Thank you for your attention
  2. Areometer
    578
    Tyngsboro, MA
    9006 HIR Bulb for your fog lamps
    IPF ‘HiR’ / 9006(HB4) / White (3800K) / 55=120w
    [Broken External Image]:http://www.sigmaautomotive.com/ipf/hir-s.jpg
    Description: An IPF innovation technology produces a brilliant white light that is double the intensity of other bulbs with the same wattage, with up to 72% higher lumens per watt. A special reflective coating to the outer surface of an HIR bulb allows visible light to pass through while infra red light (not visible to the human eye) is reflected back onto the filament. This recycling effect superheats the filament thus increasing light intensity. 50% longer lifespan, 50% more energy efficient, lower operating temp. & improved beam pattern over stock halogen. DOT & ECE R37 approved. Made in Japan. (Sold in pairs)
    MSRP: $110 | PriusChat: $99 /pair (UPS Ground incl.)
    Description: Halogen Infrared Reflective coating bulb that consumes 55w but outputs more than 2x the brightness of stock halogen. Color temperature resembles stock HID headlights found on Prius. Made in Japan. (Sold in pairs)
    MSRP: $124 | PriusChat: $99 /pair (UPS Ground incl.) - very limited supply!
