Gear shifter on 2004 Prius not smooth
Discussion in 'Gen 2 Prius Main Forum' started by AllenZ, Feb 14, 2014.
  1. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    It's been about 2 year almost. The shifter is difficult shifting from default position to Drive position. It's like there is some (plastic) obstacles on the way, right at the turning point. I have to force it to the drive position, and I hear the pretty loud clicking sound
    Sometimes it also stuck in drive position (if I don't force it back), but will come back to default position in 10 seconds by itself. It is unlikely some external objects got into there I believe.
    Have you heard anyone had this problem? Do I need to do something about it?
    Thanks!
  2. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    There are usually some available on eBay at any given time.
    SCH-I535
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    xpcman likes this.
  4. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Your shifter assembly is defective. Get one from eBay to DIY or go to dealer to let them exchange. Do asap as driving at this situation is dangerous.
  5. dorunron
    3,318
    1,103
    Houston, TX
  6. AllenZ
    640
    63
    Chicago
    Thanks All!
    That should give me enough information to get this fixed at low cost.
    Consider the problem solved :)
  7. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    I've also read on this forum that a piece of plastic can become warped, causing the problem. Subsequent removal of said piece has corrected the problem at least on one occasion. The mechanically inclined may be able to see the problem, once the shifter is removed. Removing is not particularly difficult as it is essentially a switch assembly - - no cable or mechanical linkage. I believe that the panel upon which it is mounted snaps in.
  8. Mike500
    Mike500 Senior Member
    2,593
    764
  9. Mike500
    2,593
    764
