Gearing up to replace my 2007 Prius HV Battery with a brand new one.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by carfulan, Apr 8, 2024.
  1. carfulan
    carfulan Junior Member
    Wisconsin
    A few days ago, my 2007 Prius (~88,000 miles) had the master warning light come on, and it was joined by the VSC light, brake system light, and check engine light. I didn't have my TechStream setup available at the moment, so I took it to AutoZone, where they only could pull a C1310 code. Through research on here, the code only seems to come on when there is an issue with the Hybrid Battery system. I had a tech at work pull the codes with his SnapOn scanner, which gave the following:
    P0A80 - Replace Hybrid Battery Pack
    P3000 - Battery Control System
    B1771 - Passenger Side buckle switch circuit malfunction
    (Appears to be unrelated)
    The vehicle still was pulling ~45 MPG, which left me confused. Before spending $2,000 on a new battery, I did the following:
    -Replaced the 12V battery. Found water near the 12V, cleaned it out and applied Flex Seal spray to the weld seams as suggested by the forum. Codes went away for a day, then came back.
    -Inspected the battery fan harness for corrosion. None to be found.
    Feeling defeated, I connected to TechStream, and was greeted with the previous codes and:
    P3018 - Battery Block 8 Becomes Weak
    While watching the voltages on TechStream, I noticed block 8 was sitting at about 15.8, and as a low as 14.95. The next day, I got in the Prius to drive it, only to find it wouldn't go over 30 MPH. This all seems to confirm that the battery is shot to me. I'm able to purchase a brand new OEM battery from a Toyota dealership for $1,700 (And a $1,350 core charge on top of that). Before I do that, are there any other things I should check to ensure this is the right thing to do? I'm planning on doing the installation myself, as they're up to about $189/hr for labor, and I can guess this would be a 4-5 hour project for the techs. I've found the following threads on here to do the install:
    Replacing the hybrid battery with a new Toyota battery | PriusChat
    Hybrid battery replacement using a new Toyota battery | PriusChat
  2. Tombukt2
    Tombukt2 Senior Member
    12,831
    2,307
    Durham NC
    No this sounds relatively reasonable given the fact that even at 88,000 you're about over the 10 years or 8 to 10 in normal hybrid battery last so you're in the realm of good thinking we've done this two or three times now You could play games with the battery if you wanted to and replace the modules in the block you're dealing with but personally like for my flashlight when it's time for batteries we go to the store and get new ones not try to refurbish or play with the old ones. Seems to work well. Once you do drop that in you're good to go and your batteries the least of your worries for a while. Where you found the water sitting in the 12 volt tray You need to take the 12 volt out of there for a minute and feel around there's some rubber plugs that you need to just push down on and they'll fall down into nowhere but will create a water pass through I've even drilled a few extra quarter inch holes in places where I put my garden hose in the water would still stand even with the plugs removed so when I got finished when I run my garden hose and turn it off now all the water passes right through that battery tray in the winter that water standing would freeze and ruin the battery I also did the same thing on the other side where the tool container goes where the battery is on the driver side but there's not a battery there same plugs few extra holes drilled water passes through under the spare tire right under the HV battery but in the spare tire well there's another plug push your finger through it let it fall on the ground If you must retrieve it just throw it in the spare tire weld and let it roll around now water will come in but it will pass through and cause you no grief I do this to all of my Prius generation 2 and 3 included have both models here on the property.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,030
    1,959
    NJ-USA
    You could look at the freezeframe data for the P3018, or clear codes then monitor only block voltages and pack amps with that snap on scantool and go for a drive.
    If you see that block 8 is about 1.0 to 1.5 V lower than the other blocks when accelerating (discharging at high amps) that's the "nail in the coffin" indicating that a cell in a module has failed. That same block will go higher than the others when decelerating (charging at high amps).
    If you want to DIY the replacement, study the procedure - factory service manual and youtube. Use caution (and gloves) around high voltage. Torque all HV connections to spec (48 INCH-pounds) with a torque wrench. Take lots of pictures at every step for reference. Inspect the orange connector socket and pins on the battery ecu for corrosion - could be dull black or green stuff (bad) instead of gold (good).
  4. carfulan
    Wisconsin
    Thanks for your input. As a not so thrilling conclusion, the dealership quoted me 3 hours for the battery replacement, about $580. I figured that’s low enough to pay someone else to do it professionally and not have to worry about the safety aspect of it. I’m about to go pick it up, and I look forward to putting many more miles on it.
  5. pasadena_commut
    pasadena_commut Senior Member
    2,535
    756
    Southern California
    You also get an extra year warranty on the battery because they installed it.
    For me the calculation went the other way, I wasn't going to pay $600 for something I knew I could do myself. Well, with a little help from my son to lug the battery around, as it is pretty heavy and is really awkward and bulky when it is in its shipping coffin. The only special tool I had to buy was a small beam torque wrench for use in the in-lb range, and that was on sale for $20 at Autozone. Piece of crap tool though, the beam bent after a couple of usages. The same wrench seems to be sold under different names at other auto parts stores. At least they look identical, other than the labeling.
    https://www.autozone.com/wrenches-pliers-and-cutters/torque-wrench/p/performance-tool-1-4in-drive-0-80-in-lbs-torque-wrench/752621_0_0?searchText=torque+wrench
  6. gallanbile
    gallanbile New Member
    Try letting the car charge up the battery and then clearing the code. If it comes back within a week, go ahead and replace the battery.
  7. Sbrav77
    Sbrav77 Junior Member
    Illinois
    I just had to replace the hybrid battery pack in my 2007 Prius with 103,000 miles. Same error code and same cell block. I found a local company that had a remanufactured battery with 12 month warranty for $999.00. They also only charged $350.00 to come change the battery in my driveway.
  8. mr_guy_mann
    4,030
    1,959
    NJ-USA
    If the pack fails within 12 months, what do you have to do in order for this company to warranty it? What kind of diagnostics? Who pays for that?
    Will they come to your house for the warranty work?
    Just thinking out loud. Hope you don't need the warranty, but better to understand it now instead of trying to find out the details when it's not convenient.
    Brian1954 and Tombukt2 like this.
  9. hole_shot58
    hole_shot58 Junior Member
    Plano, Texas
    I put a Greentech rebuilt drive battery (4yr wty) in my 2007 about three years ago after playing whack-a-mole with modules for a couple years. It did great for two years, then threw a code. They swapped out the whole thing and are now using 15 volt cylindrical cells which handle heat dissipation more effectively. Been over a year with no trouble, and about a year left on wty. Not bad for $1800! 160K miles and driving as good as ever.
  10. Tombukt2
    12,831
    2,307
    Durham NC
    That's actually been pretty rare to make happen w round conversions until welp today I guess . Reports all over net. But to put that in perspective about 3 years ago I bought a brand new Toyota Panasonic EV battery for the 1600 you paid for the round cell conversion You had to install that round cell conversion and wire it and put it back in the car All I did was drop my front end on my battery from the Toyota dealer drop it in the car close up the back and it should be there 10 years for the same 1600. The round sales I've never heard anybody making over maybe 2 years and generally spending more than the 16 maybe 25 26 something like that of course prices have come down. So there's always that and maybe round cells whatever they are are getting better or something.
