Gen 1. Code 3000
Discussion in 'Generation 1 Prius Discussion' started by bigblock67, Nov 22, 2022.
  1. bigblock67
    bigblock67 433K with new cells
    171
    35
    Indiana
    2002 Prius
    An 02 is stumbling at idle and run up. Code 3000. Changed plugs; and wires; mass air flow sensor
    Need advise on this please
    Thanks
  2. PriusCamper
    PriusCamper Senior Member
    11,106
    4,520
    Pacific Northwest, USA
    Isn't there a letter before the 3000 code? If not the device that's reading the error codes isn't programmed with Prius Specific error codes. What type of device are you using?
  3. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    I've read this code can be caused by corroded pins in the HV battery connector going to the battery ECU. It's a simple check to pull the connectors under the carpet in the trunk and inspect the pins.
    Clean the throttle body to see if this helps with the rough idle.
  4. ChapmanF
    15,702
    The bigger problem here is that P3000 is one of those 'hearsay' codes. It comes from the HV ECU (which lives under the carpet at the passenger's feet) and it only means "hey, I heard from the battery ECU there's some problem back there, get his trouble codes to find out more."
    And you haven't got the battery ECU code(s) to go with it, which are what would tell you in detail what the situation is. If you used a scan tool that showed you the P3000 but didn't show you the original code(s) responsible for it, a better scan tool that shows the original code(s) would be helpful.
