Gen 1 Prius availability
Discussion in 'Generation 1 Prius Discussion' started by raven waters, Oct 24, 2009.
  1. raven waters
    raven waters New Member
    baxley ga
    2001 Prius
    My 2001 Prius needs a new main battery and inverter, it cost too much and too little of a warranty. Any suggestions on what to do with it. It is in great shape otherwise.
  2. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    if u can, get two gen 2 batteries and rebuild the gen 1 pack, itll cost you less than 1000.
    are you sure the inverter is bad?
  3. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    Agreeing that diagnosing multiple failures is tricky in Prius. Make sure the 12 volt battery is right first, because a problem there can trigger DTCs in error. If problems persist, ideal would be to swap in a known-good HV battery and then re-diagnose.
    The largest parts listing seems to be
    www.car-part.com
    where at present, both used inverters (search: Power Inverter (Hybrid) ) and HV batteries are about $450 and up.
