Gen 1 Wiper motor
Discussion in 'Generation 1 Prius Discussion' started by velosolex50, Oct 30, 2020.
  1. velosolex50
    velosolex50 Junior Member
    Isle of Man
    2001 Prius
    NHW11 2001 UK spec
    I need to replace the windscreen wiper motor- it's no longer available from Toyota or the usual aftermarket places in UK.
    Anyone know if there is an easy substitute? I'd rather not be drilling mounting holes/rewiring plugs etc unless absolutely necessary.
    Yours hopefully......
  2. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
  3. ChapmanF
    15,402
    How has it failed?
    Sometimes, with cars of a certain age, one gets more likely to start popping things open and cleaning contacts, looking for replacements for carbon brushes, or whatever.
  4. velosolex50
    Isle of Man
    2001 Prius
    Thanks for the Cardone link, sometimes overseas shipping is the only answer.
    I took it all to bits and found that the magnets had come unglued from the motor casing and were clutching the armature like limpets.
    Everything else looked OK, no shorts or open citcuits in the armature so I cleaned it all up, and am now waiting for the epoxy to set before trying it out.
    Strange that there are so many variations in what one would think was pretty much a universal part, like the old round headlights. Progress?
    Kadalora likes this.
  5. ChapmanF
    15,402
    Ok, that right there is a failure mode that would never have occurred to me.
  6. velosolex50
    Isle of Man
    2001 Prius
    Rust gets everywhere in Britain!
    Epoxied the magnets back in the casing, taking care to put them in the original orientation, identified by looking at the "jigsaw puzzle" pattern in the glue remnants, and it works!
    Nice to be able to fix something so simply.
    A useful dodge for reassembly was to first fit the armature into the gear casing and engage the bearings & brushes with good access. Then hold the armature in place with a single loop of dental floss while putting on the casing, to prevent the magnets pulling the armature out & disengaging the brushes while sliding on the casing.
    Happy days. Now if I can just sort out the annoying warning lights on startup.......
    Kadalora, Itsmeonprius and WHCSC like this.
  7. Kadalora
    Kadalora Junior Member
    New Zealand
    2002 Prius
    Oh boy I'm so thankful you made this post!!!! The EXACT same thing just happened with my Gen 1 NHW11 2002 Prius! I'm unfamiliar with wiper motors and quite possibly wouldn't have realised this was the problem without your post. Google suggested it's often an issue with the carbon brushes, so I took it to an auto electrician and he said the brushes were fine, then he went to turn the armature by hand and at first thought it was seized, but then suddenly the armature and magnets all turned together. His immediate response was to bin it and source a replacement... at this point I'd already read your post so knew there was a better way!
    I followed your reassembly method, I wasn't sure what you meant about 'good access' but assume you mean have the brushes pressing directly against the lower part of the armature. This particular step was incredibly difficult to do alone.. as there are 3 brushes you have to try and hold back to push the 'worm' back into the gear casing fully... by miracle my Dad turned up after much struggling the two of us were finally able to do it. And eventually I realised you meant hold the floss along the length of the armature to stop it pulling back via the magnets towards the housing.. this was a great idea indeed
    There was a light bit of rust on the glue side of the magnets and housing so while everything was apart I sanded it all off using a rough grit sandpaper so the new glue would adhere well. I made sure to mark with a vivid (on the rim) where the magnets had been glued so I could re-glue them in the same spot. After sanding, I wiped it all clean then treated everything except the magnets with rust proofing liquid product. I avoided treating the magnets as I was worried it may interfere with the glue adhesion and/or operation of the wiper motor
    Just thought I'd let you know I found it very useful anyway, thanks again!
    PS: So we can now reasonably assume whatever glue they used has a life expectancy of about 20 years.. not bad I suppose, here's to another 20 with the new stuff!
  8. ronlewis
    ronlewis Active Member
    865
    178
    texas
    2001 Prius
    I have spare wiper motors if anyone needs one.
  9. ronlewis
    865
    178
    texas
    2001 Prius
    oopsssss
    #9 ronlewis, Jan 9, 2024
  10. ChapmanF
    15,402
    Haven't had one of these apart, but often in brush holders one will find small holes, through which a pin or piece of wire can be stuck, to hold the brush back, and pulled out once the armature is in place.
  11. Kadalora
    New Zealand
    2002 Prius
    Yeah I was thinking while doing it that would've been a great invention.. hah, no such luck. Here's the inside of it: (see pic)
  12. ronlewis
    865
    178
    texas
    2001 Prius
    Great work, guys. There's just so many used wiper motors out there. Seems like the easier solution.
  13. ronlewis
    865
    178
    texas
    2001 Prius
    Except to above statement granted for NZ residents, et al. I realize you gotta make it happen one way or the other.
