Gen 2 brake pipe
Discussion in 'Gen 2 Prius Technical Discussion' started by Ajj, Dec 29, 2024.
  1. Ajj
    Ajj Junior Member
    uk
    ----UK----
    Hi my brake pipe has split at the rear curved section that doesn’t have the plastic sheathing on. Connected to the flexi.
    Would it be possible to add a short section instead of the full length. Many thanks
  2. Ajj
    Ajj Junior Member
    uk
    ----UK----
  3. Ajj
    Ajj Junior Member
    uk
    ----UK----
    #1
  4. Hayslayer
    Hayslayer Active Member
    461
    265
    If you're talking about the steel tubing, then yes, repairs are often made by splicing in a short length of replacement tubing. The location of the damage and condition of the remaining tubing determines whether the line needs to be spliced/flared on both ends or just one, with the other end going directly to an oem fitting.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    Possible but very difficult. The only safe method of splicing in new tubing requires proper flaring tools.
    You have to strip the plastic off of a straight section on the car. Cut the tubing, put on the fitting nut for the splice (inverted flare or DIN-bubble), then flare the end). Make sure to use or form the correct OE type end at the brake hose.
    Do NOT use a "compression" fitting, as it is not rated for brake system pressures.
    My first choice is to get a new OE line if possible. Otherwise get a roll of Nickel-Copper brake line and replace the entire piece.
