Gen 2 C1344 code when raining only
Discussion in 'Gen 2 Prius Main Forum' started by ShepardF14, Oct 16, 2019.
  1. ShepardF14
    ShepardF14 New Member
    NOVA Virgina
    Hello,
    I have a 2009 Gen 2 Prius that throws the C1344 code only when it rains, no other time. When the rains stop and it's dry outside, I clear the code and the car is fine until it rains again. I've been searching the web and so far the problem other owners have with this is a wiring problem in the LR location of the car near the brake.
    My question is what sensor/switch location in the rear brake of the car could be where water is getting into.
    I'll put the car up and examine for wiring or connector opens but wanted to check here first to learn what else to look for.
    Thanks in advance!
    49,571
    the only thing i can think of is the wheel speed sensor, but there might be other stuff for abs and etc
  3. PriusCamper
    PriusCamper Senior Member
    11,119
    4,527
    Pacific Northwest, USA
    Has the behavior of the skid control/traction control light on the dashboard changed? It's normal for that light to flicker a bit when the wheels slip, and perhaps if that light is not flickering the system that reacts to tire slippage has something wrong with it? Of course this is all integrated into the ABS system and there's lots of different things related to this. But first step is if you have any additional symptoms to help narrow the options of what to look at next?
  4. ShepardF14
    NOVA Virgina
    No other symptoms. All the lights come on at the same time, minus the triangle of death.
  5. ShepardF14
    NOVA Virgina
    I'll try spraying the wiring connections with WD40 and see if I can waterproof it. Who knows I might get lucky the find a cable open.
