Gen 2 Catalytic Converter Stolen - Don’t Know What to Do
Discussion in 'Gen 2 Prius Main Forum' started by Nathan James Byrd, Mar 7, 2021.
  1. Nathan James Byrd
    Nathan James Byrd Junior Member
    Dallas
    Hello!
    I live in TX in the Dallas area. My catalytic converter was stolen and I’m not sure what to do. Will a replacement such as the one on Amazon in the link below work? If so, what else will I need to replace it? I am not very handy with cars at all so how difficult is it to replace myself, or does anyone know how I could find a place that would replace it using one that I buy?
    Thank you for any assistance!
    here is the link:
  2. Tanner2017
    Tanner2017 Junior Member
    ames iowa
    I just went through this. The new one needs to be welded on. Take it to a muffler shop and they will do it. Also ask them to put a shield on to prevent it from happening again.
    Nathan James Byrd likes this.
  3. Socal_Prius
    Socal_Prius Junior Member
    36
    Santa Barbara, CA
    Furthermore, you may need a new O2 sensor if they clipped that, and also the inner gasket 'donut' which aftermarket units are prone to leak, ours was kind of cracked so I decided to buy a new OEM unit in order to get a proper seal on our aftermarket unit. Hopefully this car is good for another 50k+ as the guys in the shop stated.
    You can do it yourself if you're motivated enough, but you'll need to weld the unit to the resonator (assuming that's intact) to ensure a proper seal and avoid leaks and aligning it while on the ground isn't impossible but worth having someone do it if you don't have a lift. The little clamps that come with aftermarket units are worthless and will leak after a few miles.
    PS: Mods can you whitelist me? I can't even quote without modfying people's posts. Thanks!
  4. dolj
    dolj Senior Member
    8,446
    4,291
    Wellington, New Zealand
    As you were new your posts were moderated. But now that you have more than 5 posts you should be good to go. Moderation is an unfortunate consequence of the forum being attacked by spambots.
    #4 dolj, Mar 11, 2021
    Socal_Prius likes this.
  5. Socal_Prius
    36
    Santa Barbara, CA
    Thanks, mods!
