Gen 2 no communication with OBD port.
Discussion in 'Gen 2 Prius Technical Discussion' started by Aidan R, May 14, 2025.
  1. Aidan R
    Aidan R New Member
    Prince Edward Island, Canada.
    Hey everyone. I have an odd issue with my 2008. I’m a mechanic with 10+ years experience but I’m a bit stumped. (and would love some help)
    So Figured I’d turn here first before going crazy with trying to diagnose the issue.
    I can’t connect my obd scan tool, been an issue for bit but car ran fine. Then red triangle today. (May/14/2025)
    Found the 7.5A OBD fuse blow at first, replaced it and red triangle went away so reconnected scan tool and still no communication with car.
    then red triangle came back up.
    Checked the OBD fuse again and NOT blown this time. Try a few times to reconnect and manually enter VIN etc. no luck. I have to try my OBD break out box tomorrow to see what pins in the OBD port are working and which are not.
    But again before I go crazy and spend hours going through diagnosing this I was hoping someone else maybe had this issue and can let me know what the fix was for it
  2. dolj
    dolj Senior Member
    8,180
    4,167
    Wellington, New Zealand
    Have you checked any other fuses, like the AM2 or EFI fuses?
    Aidan R likes this.
  3. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    On right track they're have been a few issues . I had same in gen3 for days after engine change it just started working again about 5 days later . Still do not know what twas. There is a section in the manual about troubleshooting the OBD2 port.
  4. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Did you try the OBD tool on another car, or another OBD reader on the prius? I had a cheap one die years ago.
  5. Aidan R
    Aidan R New Member
    I will today. I’m getting the car out to my shop to get a better look
  6. Tombukt2
    11,994
    2,119
    Durham NC
    I've had cheap scanners that won't even recognize the car plugged in and does nothing just sits there go to a General motors car and it fires right up the scanner that is got a few sitting around here that can do this today but they're real old apparently he's plugging it in and it's doing something.
  7. pasadena_commut
    pasadena_commut Senior Member
    2,214
    661
    Southern California
    Verify that the OBD2 dongle works on another car.
    Inspect the OBD2 port connectors for corrosion or other physical damage.
    Did this OBD2 dongle ever work with that port? I had one dongle which simply did not fit one of our cars (don't recall the combination), nothing was broken per se, but the sizes were just slightly incompatible.
    Follow the wires up from the OBD2 port and look for aftermarket modifications - sometimes cars bought used have trackers installed there, which can later cause electrical issues.
    Follow the manual section on OBD2 problems.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    3,938
    1,900
    NJ-USA
    Do a pin drag check of the data link connector terminals. Verify good grounds at pins 4 & 5.
    A Gen2 uses CAN at pins 6 & 14 for scantool communication to ECM, hybrid control, & high voltage battery ecu's. Pin 7 is SIL (ISO 9141-2) and is for scantool comm to everything else - the ecu's on the BEAN bus (Toyota LIN) go though the gateway module.
    Brian1954 likes this.
  9. black_jmyntrn
    black_jmyntrn Senior Member
    1,690
    392
    2013 Prius Plug-in
    yeah.. if you cant confirm it works in another car it might just be the dongle.
