Gen 2 OEM Spark Plug diagnosis help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gatoman39, May 25, 2017.
  1. gatoman39
    gatoman39 Junior Member
    Netherlands
    2006 Gen 2 Prius. Can anyone diagnosis the condition of these plugs? They all looked the same but cylinder 4 looked wet at the base. Car burns 1/2 quart per 1500 miles.
    California model 140k miles. Swapped the OEM plugs and PCV valve today. IMG_9050.jpg IMG_9028.JPG IMG_9033.JPG IMG_9045.JPG
  2. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    Many Gen2 engines start consuming some oil at around 140K miles, and your consumption sounds okay.
    The oil at the threads could be from a valve cover gasket leak. What did the coils look like, and did you look into the wells?
    The deposits on the tips are probably from the oil consumption, via worn rings.
  3. gatoman39
    Netherlands
    The car has been consuming oil since around 80/90k. The coils were completely dry. I didn't look into the wells. Could a oily #4 be caused by a partially blocked PCV valve?
  4. Mendel Leisk
    38,874
    How are you ordering the plugs? For example, standing at the front of the car, #1 is on your left, #4 on the right?
  5. gatoman39
    Netherlands
    Correct. Facing the engine as if to remove the plugs from left to right 1-4. 4 closest to PCV. Is this correct?
  6. Mendel Leisk
    38,874
    Sounds good. (y)
  7. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    Fairly normal with light ash deposits, #3 looks like it is a little lean. What are your fuel trims?
  8. gatoman39
    Netherlands
    Not sure what fuel trims are. I am getting about 43mpg in mixed driving on 17inch summer tires.
