Gen 2 prius all lights on
Discussion in 'Gen 2 Prius Main Forum' started by GeorgeMW, Nov 17, 2017.
  1. GeorgeMW
    GeorgeMW Junior Member
    57
    Georgia
    when i turned the prius on, all the lights came up and the car would not start, also there was no READY greenlight
    any suggestions on what happened?
  2. GeorgeMW
    57
    Georgia
    also the monitor where energy consumption and A/C status is seen, is just black, no light from there as well
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    12v battery dead?
  4. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Check the 12volt battery, and also the HV battery. If you aren't getting the Ready on, its likely the 12volt battery
  5. bisco
    51,141
    how many miles on her?
  6. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    If it just cycles between acc and ig-no, newer going to ready, it can just be the brake light switch. Try pushing the brake really hard to get it started? Do brake lights come on when pressing brake pedal?
