Gen 2 Prius Battery Fan Cleaning Procedure?
Discussion in 'Gen 2 Prius Technical Discussion' started by veggieranger, Jun 16, 2012.
  1. veggieranger
    veggieranger Junior Member
    37
    Peachtree City, GA
    I have my 2004 Toyota Prius taken apart to replace the HV Battery. (waiting on a reman battery on its way from Fedex) I was reading Luscious Garage's post about cleaning the HV battery fan since it doesn't have a filter:
    Luscious Garage | Blog | Prius battery cooling fan cleaning, P0A82
    However, I can't find any Youtube videos or Priuschat posts on the proper procedure for disassembling the fan for cleaning.
    The fan is fully exposed right now and it looks pretty straightforward but thought I'd check to see if anyone has done this before and has any tips?
    I'm already videotaping the HV battery replacement so I'll do the same for the fan cleaning since it sounds like this should be mandatory when replacing a failed HV battery. (as well as a regular maintenance procedure every 60k or so)
    -VR
  2. veggieranger
    37
    Peachtree City, GA
    I just searched in my Bentley's manual and there are no instructions regarding the HV Battery cooling fan/blower. There is just one picture on 2-33 in a cooling flow diagram.
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    There's no smoke and mirrors here. The hardest part is getting to the fan and since the squirrel cage is exposed, verifying if it's dirty or not only takes 10 seconds or so. I took mine apart at 171K for the first time. It only had a light coating of dust and would probably work fine for another 500K miles or so.
    snead_c likes this.
  4. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    I venture to guess that you don't carry pets in your car on a regular basis?
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Nope. It's a pretty obvious thought that the fan will become filled with crap if the air entering it is dirty.
  6. Silver bullit
    608
    210
    Thank you for your friendly response
  7. veggieranger
    37
    Peachtree City, GA
    thanks for the feedback. The reman battery arrived yesterday and I'm going to clean the fan and install the battery this weekend. Hoping for a good outcome and a clean blower fan so I don't have to worry about pulling it apart for cleaning regularly! (we have a short-haired Terrier that only rides in the car on occasion)
    -VR
  8. veggieranger
    37
    Peachtree City, GA
    I worked on this yesterday. There are three black plastic tabs with center pins that hold the upper duct in place. My upper duct had two air filters on it but no obvious way to replace or clean the elements. (covers were riveted on) Once you release the three tabs with a trim tool, the fan blades are exposed. Mine were covered in lint and dust to where the blades were no long shaped in a curve. I cleaned them with a small brush and vacuumed out the lint and dust with my shop vac.
    This was definitely reducing the air flow to the battery pack.
    I'm going to clean it every 60k or so to prevent this buildup.
    I took video of the process since I was videotaping the battery replacement procedure. The reman battery pack is in and tested with about 40 miles on it. I just need to re-assemble the trim pieces and back seat so I can drive it next week to further test it.
    -VR
  9. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    Congratulations on your successful install. I'm looking forward to the video. :)
  10. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    Me too but I hope I never need to use it!
  11. veggieranger
    37
    Peachtree City, GA
    I just posted the part 1 video on another thread.
  12. mfa-prius
    mfa-prius Old member
    299
    45
    Hansville, WA
    I just cleaned mine today at 125,763 miles. A light coating of fairly tough grime, I used a 1/2" bottle brush to go down between the blades and out the back of the fan to make it squeaky-clean. Probably could have been done without removing the fan if you were careful to suck the dislodged grime out of the ductwork with a Shop-Vac or some such. Would really pay to have a bunch of replacement trim fasteners handy.
