Gen 2 Prius Engine Block Heater Help
Discussion in 'Gen 2 Prius Main Forum' started by T.S. Elliot, Nov 3, 2018.
  1. T.S. Elliot
    T.S. Elliot Junior Member
    60
    Desolation Row
    Hello all. I am trying to install an EBH on my prius and I was unable to complete installation. The core is installed, but the electrical connection I could not make. The access needed to perform this job is tiny and my arm is too big basically. I got up in there but didn't have the strength to make the connection 100% blind.
    Is there an alternate way? I seem to remember you can remove the wipers and cowling. Would that work to free up access from the top? Does anyone have instructions for that job? What about removing the inverter coolant reservoir. Never done that before, don't know if it's necessary or easy/possible. I've never actually had to do it. When I did PCV I just used a wrench and same with the spark plugs I think.
  2. T.S. Elliot
    60
    Desolation Row
    Also I almost forgot to add. I seem to have encountered a possible problem with my frame or engine mounts. I will hope to get a photo of the actual area next time I attempt this job. Here is my best explanation with drawing. There is a triangular shaped frame piece with three bolt holes. 2 of the 3 are bolted down, but the third hole insead has just a loose nut on the top and no bolt going through it. That being said it's not going anywhere, just not connected. To orientate yourself, the part is parallel to the road and the part with the missing bolt faces to the rear. PRIUS.png
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Hmm... Hard to say without seeing it... Perhaps look at exploded view parts diagram to figure it out?
  4. Mendel Leisk
    40,584
    Maybe it'd help to pull the core back out and plug in the power cord, then reinstall?
    Skibob and PriusCamper like this.
  5. T.S. Elliot
    60
    Desolation Row
    Tried it, but then the entire assembly seemed too long to give me enough clearance to get the job done. She's a hard f***.
  6. Mendel Leisk
    40,584
    #6 Mendel Leisk, Nov 3, 2018
  7. T.S. Elliot
    60
    Desolation Row
    Yeah this is the guide I was working off. Just reaching it required considerable abrasion on my arm and then I finally tired out and lost stamina. Will try again tomorrow and then not sure.
  8. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    Removing the wipers and top cowling is not that hard. Pull wipers.. and some plastic trim, and I think there are 8-10 10mm bolts. And an electrical connection for the wipers. It's not hard.. maybe 14 min job.
    T.S. Elliot likes this.
  9. Mendel Leisk
    40,584
    Does it help though? Not saying it doesn't, just to weigh the pros/cons. He was able to install the core from below.
