Gen 2 Prius: Water in trunk -> U0293 code. Radiator fans run at max speed, ICE starts for 15s
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MutiVinas, Jun 13, 2026.
  1. MutiVinas
    MutiVinas New Member
    Poland
    Hi everyone,
    I am facing a very frustrating issue with my Gen 2 Prius (2007) and really need some expert advice.
    Background:
    A few days ago, I discovered that the trunk was severely flooded (water accumulated in the spare tire well and heavily leaked into the left side quarter panel area). The car locked up, threw a P/S warning on the dash, and the radiator/cooling fans under the hood (front of the car) started running at maximum speed continuously as soon as the ignition was turned on.
    What we have done so far:
    1. We completely drained the water and thoroughly dried out all the wiring harnesses and connectors visible in the trunk using a heat gun/hairdryer.
    2. We removed the trim panels to access the Battery ECU. We inspected the unit, and physically, the module and its pins appear to be completely dry and clean inside.
    3. We even swapped the Battery ECU with another known-good working unit, but the exact same symptoms persist.
    4. We followed the reset procedure by disconnecting the 12V negative terminal and removing the orange HV service plug for over 20 minutes to clear the deep memory, ensuring the service plug was properly slid down and locked back into place.
    Current Symptoms:
    When we clear the codes via OBD (using Car Scanner) and press the Start button, the ICE (Internal Combustion Engine) successfully fires up. However, it runs extremely rough with violent shaking and vibrations. After exactly 10 to 15 seconds, the car automatically stalls/shuts down. The front radiator fans continue to blast at maximum speed. Once it stalls, the scanner brings back only one single, stubborn active code:
    U0293 (Lost communication with hybrid powertrain control module).
    My Questions:
    Since the front radiator fans are blasting at max speed, it feels like the main ECM or HV ECU is in a fail-safe mode due to the lost communication. Since the Battery ECU itself seems fine (tested with two units), could the water in the trunk have caused a short circuit that blew a specific integration relay up front, or damaged the CAN-Bus line entirely? What should be our next step to diagnose this U0293 loop?
    Any guidance on which specific wire pins, fuses, relays, or hidden connectors to check next would be highly appreciated.
    Thank you so much in advance!
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    Test 12V battery . Check the white plug above 12v battery look at it carefully . All that flooding renders a battery showing volts with nothing behind the volts switch in a load . Boom nothing .
    MutiVinas likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,465
    5,432
    Pacific Northwest, USA
    Not related to your problem: The water damage you described in Gen2 is common and is likely coming from roof seams you can see under the black roof trip strips as well as areas you can see when rear hatch is up. Clean them and add some silicone or equivalent in the cracks.
    What the problem is: The engine is failing to start. The 15 seconds is just the electric motor spinning the engine trying to start it. Keep in mind if you spin an engine that won't start too many times you drain your hybrid battery down and recharging it without a functional engine is a whole other hassle we can walk you through.
    Solution: If I were you I'd swap out the ECM after you thoroughly inspected and haven't found any damaged wires. Then I'd probably look at engine temperature sensors to confirm they're working normally. And If that doesn't work I'd look at the spark plugs for clues, maybe use a borescope to see what's going on inside there. Clean and inspect Mass Air Flow sensor and throttle body and all this is assuming you followed @Tombukt2 advice on 12v.
    PrimeDan, Brian1954 and MutiVinas like this.
  4. MutiVinas
    Poland
    I tested, ı tried with cable, i tried to change with new battery i tried all. I will keep trying thanks man
  5. MutiVinas
    Poland
    your explanation completely opened my eyes. I thought the engine was actually running roughly on its own, but what you said makes 100% sense—it is the electric motor (MG1) violently spinning a non-starting internal combustion engine. Thank you for warning me about draining the HV battery, I will stop trying to force-start it now to protect the hybrid battery.
    Based on your advice, I will shift my focus to the front of the car. I will check and clean the Mass Air Flow (MAF) sensor and the throttle body first. If that doesn't work, I will check the spark plugs and look into the ECM
  6. pasadena_commut
    pasadena_commut Senior Member
    3,067
    951
    Southern California
    Why was the trunk flooded? Did it rain heavily or was the car at least partially submerged? In the former case it is probably the usual sorts of leaks into the trunk and the front of the car would not be affected. However, if the car was actually flooded then all the wiring below the water line is now suspect, including and especially the wiring to the fuel pump in the gas tank. ICE motors don't run without fuel!
    Assuming no flooding, parking it in direct sunlight with the doors open (and 12V battery ground lead detached) for a few days might be worth a try. This could still be just "wet wires", and that would help the water evaporate.
    Was the hybrid pack actually wet inside? Typically trunk flooding fills up the low points, like around the 12V, but doesn't rise up into the pack.
  7. PriusCamper
    13,465
    5,432
    Up here in the Pacific Northwest I'd say 70% of all Gen2 Prius I've worked on have standing water in the rear of the vehicle... It's amazing how many bad hybrid battery packs I've pulled in winter that are wet too. As in we have highest year round humidity in the US up here and we only get a couple-few months of a dry season.
  8. Tombukt2
    13,863
    2,519
    Durham NC
    Seems like somebody up there in the pack Northwest needs to be pushing these rubber plugs out the back of these Wells in corners of these cars.
  9. PriusCamper
    13,465
    5,432
    Yep... It's easier than fixing leaks. Worst case scenario was a 2001 Honda Insight I installed Muddler's Lithium kit in and vehicle's owner had 2-3 gallons in the spare tire wheel well and when she slammed on the brakes hard all the water went forward soaking the circuit board and causing delamination to the traces on the bottom of the board that held water and didn't dry out. Had to replace the whole board after that, which was not cheap.
  10. pasadena_commut
    3,067
    951
    Southern California
    Or installing replacements plugs which are flat on the inside but resemble the drain outlets that Honda uses, or at least used to use, on the ends of the drain lines from the sun roofs. These look a bit like a duck's beak made of rubber, and will pass fluid out but little to none back in. Unfortunately the darn thngs can pack up with dirt and then they don't pass anything. Easy enough to clean out, but not something most people ever think to do. This is the Acura variant:
    70052-S6A-J00 Genuine Acura Front Drain Valve (Sunroof)
    If the hole size was the same I bet one could cut off the bit above the grommet with a razor blade and install it. Not that I have any reason to think that the hole size actually is the same!
  11. Tombukt2
    13,863
    2,519
    Durham NC
    In Western Massachusetts salt hell . 8 had no issues w plugs out after 3 to 5 years the cars dead ate alive with rust . So the plugs would really make no difference other than allowing water pass thru . Which keeps batteries and things from freezing and having to be bought early etc.
