Gen 2 w 270k miles. What maintenance should i do now?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DJackson, Jan 1, 2021.
  1. DJackson
    DJackson New Member
    Bartow, fl
    I've got a 2009 Prius with 270k miles. Bought it years ago with about 90k on it and it's been a great car. only thing i've had to replace is the inverter fluid pump. Plugs have been changed...probably due for another set, though. My question is.....what would you guys do if it was yours? It's still going strong...but I've noticed it's burning some oil. How far can pads go? Don't think i've ever replaced them lol Fluid is still pink. Should I replace the belt?
    Thanks....any recommendations are appreciated..
  2. JC91006
    16,778
    8,575
    If you've done zero maintenance on this car for nearly 180k miles, you would have to change everything out. I would start with the basics like changing these items here
    1. transaxle fluid
    2. coolant (both loops)
    3. shocks/struts (pretty sure they're bad at 270k)
    4. water pump and belt (most likely leaking)
    5. inspect your brakes
    6. brake fluid
    You probably don't want to do too much with a car that high mileage
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    I wouldn’t do anything to it except maybe move up to a 40 weight oil
    Because it may be a magical car.
    donbright and Tunkamoose like this.
  4. Mendel Leisk
    41,593
    Brakes are supposed to have a full inspection every 30k miles or 3 years If I recall correctly, per Toyota USA.
    And after the first times, every 50k miles or 5 years for both coolant circuit changes.
    Plugs are every 12 years or 120k miles.
    Toyota Canada recommends to change brake fluid every 3 years or 48k kms. Toyota USA says nothing.
    I’d second transaxle fluid change ASAP. Neither Toyota US or CDN says squat about it.
    #4 Mendel Leisk, Jan 3, 2021
    Tunkamoose likes this.
  5. VFerdman
    VFerdman Senior Member
    1,186
    1,215
    Western Massachusetts
    Do not over-maintain! Seriously. It's a mistake many make. Change the oil, keep good eye in oil level if you know the car uses some. Look at pads and rotors. If worn, replace, if not, leave be. Drive it and enjoy it. I bought my '07 in '17 with 175K on it. It now has 235K and I have changed spark plugs, pads+rotors and transmission fluid. I believe that is all. I am not mentioning tires and cabin filters, those are replaced as needed. I also do a Prolong battery conditioning once a year. Still on original battery with no signs of weakness. I love this car!
    97trophy and Tunkamoose like this.
  6. ChapmanF
    18,278
    I recommend a bit more of a brake inspection than just "look at pads and rotors", on a regular schedule. Doesn't cost you anything but time, and not much of that if you combine it with tire rotation, as I do. If in a given inspection you find anything needing replacement, like as not it will be something quite cheap like the "fitting kit" (little springy clips) at around $15, and most times you won't even need those. Keeping up with the inspections gives you the best chance that you won't have to fuss with the pads or rotors for a good long time.
    Mendel Leisk and VFerdman like this.
  7. VFerdman
    1,186
    1,215
    I generally check slide pins on the front brake calipers and have taken to cleaning and re-lubing them. But I don't think it's strictly necessary if proper grease is used. Good to look over since seized up pins will cause an untimely demise of the pads and rotors.
  8. ChapmanF
    18,278
    About the most I ever do with the slide pins is pull and push on them a couple times, plus look carefully at the condition of their rubber boots. Usually they will feel rather stiff on the first pull/push, but it only takes a couple more to re-awaken the grease and they move smoothly and greasily and just fine. Only if that doesn't happen, or if I spot a crack or tear in the rubber, would I bother taking them out, cleaning the old grease out, and adding new (and replacing the rubber, if a crack or tear was the reason).
    But there's plenty more to check than just slide pins. The goal of inspection isn't so much to do any particular maintenance to any particular part, as simply to check all the possible trouble spots and notice whether there is anything that ought to be done. Most inspections will be completed with a parts cost of $0.
  9. DJackson
    DJackson New Member
    Bartow, fl
    I, too, am still on the original battery and I've never pulled the cover to look at it. Should I? What can I do for a battery bank that's still working?
  10. DJackson
    DJackson New Member
    Bartow, fl
    Great advice, guys. I replaced the struts a few years ago, but bought some cheap ones on ebay and i think they lasted just a few trips up the road! :( Never again. Still riding those bad shocks and struts, but should change them out again. What are good 'quality' prius struts? (forgive me, as I'm sure this is discussed elsewhere in another thread)
    Is it a pain to change the water pump and belt? Looks crammed in there. I think a local Prius expert said he'd charge about $200????
    So, from your advice I think I'll examine the brake system soon, change out the water pump, and change out plugs, minimally.
  11. Mendel Leisk
    41,593
    For the pros too, except they’ll charge you $20~25 extra for “shop supplies” ON TOP OF the quoted price. In the same league as airport “fuel surcharge” or “improvement” charge; basically a way to print money.
  12. Moses Bruh
    Moses Bruh Member
    97
    29
    for
    2. would a drain and flush do the trick or do you reccomend a full change?
    3. any recommendations?
  13. JC91006
    16,778
    8,575
    For the coolant, it's only a drain and refill. No flushing.
    The shocks and struts, you can buy the OEM Toyota ones for the best ride comfort (and the prices are very similar to aftermarket ones if you buy from Toyota online websites like parts.longotoyota.com). Many have purchased aftermarket KYB branded ones and they do the job just fine (although slightly stiffer ride)
    Raytheeagle likes this.
