Gen 3 2010 battery lifespan
Discussion in 'Gen 3 Prius Main Forum' started by abdullah arslan, Nov 20, 2022.
  1. abdullah arslan
    186
    78
    @260k and original battery, first time ever it failed to start due to traction battery. I thought it's the 12v but it was not, all the lights and meters on the dash were not reset. The mpg not bad, getting good like 45-50 in warm seasons and 40-45 in colder times.
    It's garage kept but not driven much as past thanks to(!) the pandemic changed working style. Also we are having early winter here in IN, 15-20 degrees for a couple days. Inside garage 45-50
    So my point is the options:
    1- should drive more
    2- recondition cells
    3- get a Li-ion pack
    The 4th would be selling it but right now not a good time to sell and buy. Wanna keep it as long as possible or a few years at least
    Any thoughts and suggestions?
    Thanks!
  2. Mendel Leisk
    40,575
    Any lights or warnings, say "check hybrid system"? Check with Dr Prius app?
  3. abdullah arslan
    186
    78
    No lights, everything works fine. But yes I forgot to run DrPrius, even though got a bluetooth OBD for that. Thanks for the reminder, I ll do it first
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    766
    302
    Maine
    Drive it more.
    Somewhere past 300k then maybe it will begin showing codes, until that happens nothing else can be done.
    I have tried quizzing the service department at my dealership, but they were not forthcoming with any advice.
  5. ASRDogman
    ASRDogman Senior Member
    7,232
    3,774
    You forgot to run the app? You can run it now...
  6. abdullah arslan
    186
    78
    Just did Life Expectancy test, it said %68.41 left but ICE turned on while keeping needle in the green. I guess that's why it said the result gave compromise
  7. bisco
    51,141
    reading your first post, i don't see any indicator that you have a traction battery problem.
    if the car would not make ready, and you're not getting any dash lights, get a load test on the 12v.
    Grit likes this.
  8. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
    You're in a good position to get this battery pack charged & balanced and deep cycled so you can sell it when you upgrade to a https://projectlithium.com/?ref=9qLPw pack means you have alot of your costs covered...
  9. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    One reply said test your 12v while another reply said buy lithium traction battery with my referral code. I’ll say... buy an $65,000 EV!!!
    Mr. F likes this.
  10. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    You can’t sell and buy your car at the same time
  11. Mendel Leisk
    40,575
    Can you do that basic test, the one with the car off, and post a screen grab? The one that shows the bar graph of voltage for each block, the resistances below and some overall data at the top.
    just demo mode:
  12. abdullah arslan
    186
    78
  13. Paladain55
    Paladain55 Active Member
    402
    161
    The South
    looks good and normal. Sounds like your failure to start might be from something else.
  14. Mendel Leisk
    40,575
    The resistance values are getting up there: could maybe benefit from disassemble and clean of all connectors and bus bars? What about swapping blocks around, or is that detrimental in any way?
  15. Pintado
    Pintado New Member
    Mundelein, IL
    I have a similar concern: just bought 2013 v with 103.000, wondering how to check the condition of the battery?
  16. bisco
    51,141
    dr prius app
