gen 3 2010 prius 4--blind spot any worse than other cars?
Discussion in 'Gen 3 Prius Main Forum' started by wpease, Sep 20, 2009.
  1. wpease
    wpease Junior Member
    23
    new jersey
    there were some posts on blind spots for Gen II but several spoke of a way to set the 3 mirrors so it could be avoided. Another thread mentioned that blind spots on the Prius (about 14 ft for a 5ft person) were actually lower than for other similar cars.
    Question--any new tips on mirror setting and handling the split horizon rear window on the Gen 111 prius? Is it just a question of learning the geometry on this car to get beyond this?
    Am going to be getting a Prius and feel nervous at the idea of driving it but I will need to get around!
    and I dont think i will attempt to master all the fine details at once, just the basics--as in basic defensive driving.
    thanks much
    W.
  2. bluemonday
    bluemonday New Member
    151
    26
    St. Louis
    You can look in the "Prius blind spot accident" thread near this one in the forum, which includes some tips from people for setting your mirrors. But I don't think there is any particular trick to it compared to other cars. I don't find the blind spots to be any better or worse than any other car I've ever driven.
    Not scientific, but one man's subjective opinion.
  3. jay_man2
    jay_man2 jay_man_also
    1,246
    143
    Manassas, VA
    Agree completely.
  4. Dirk Lerxst
    Dirk Lerxst New Member
    51
    Phoenix, AZ
    It's definitely not worse than other vehicles. I'm used to trucks and SUVs with absolutely terrible blind spots. The Prius didn't seem particularly bad when I test-drove it a few weeks back. Just remember to give a good glance over your shoulder before changing lanes, and/or do like I suggest in the "blind spot accident" thread and get adjustable convex blind spot mirrors.
  5. anniea
    anniea New Member
    59
    Atlanta
    I agree too. It was a bit challenging at first to get used to the rear view being cut in half by the spoiler, and also by the somewhat narrow width of the rear window, compared with my previous car. But since getting used to it, I've come to believe that the actual "blind spot" is not a greater issue than with most other cars--it's taken care of via mirror adjustment and looking over the shoulder, same as with other cars. The only difference is that you have to be alert that the spoiler may be partially obliterating headlights of a vehicle that's directly behind you. But I have gotten used to that, and I just check carefully.
    For several years I drove a '99 Odyssey. That van really did have an unexpected blind spot, and several times both my husband and I were amazed when a driver we never saw honked as we started a lane change. Others found this as well. This is not an issue with our Prius.
  6. tiztim
    tiztim Junior Member
    49
    Chicago
    It's not a question of the geometry of the car but the solution consists of two items found in most auto-parts shops:
    1) a small convex mirror affixed to the lower left corner of the driver's-side mirror.
    This shows a quarter-portion in a panorama, showing all traffic in lanes behind and to your left. I've used this for years and have added another to every new car I get. This little stick-on mirror is sort of the equivalent "objects in mirror are closer..." in effect.
    It's what you need. $3
    2) Backing up my new Prius was a new problem: the design of the body and placement of the lower back half-window gave me no reference to judge my distance from whatever I was backing up toward.
    Solution was a plastic fresnel lens I put in the middle of the lower rear window. This 8x10 sheet gave me nearly a 180º view behind me and what's right up near my bumper. Really an amazing effect. $10
    These two items have completely eliminated blind spots to my sides and behind me. I have always to be aware the front pillar at the windshield can hide an object behind.
  7. bwilson4web
    15,392
    It is hard to see a blind spot but the effect is the occasional 'honk' from a lane change into another car or the surprise of "where did you come from?" I've been thinking about building a side-to-side, rear view mirror that uses the visor anchor points.
    Personally, I think it is a correctable problem and was not aware of the after-market, convex mirrors. I'll stop by Autozone this morning to see if they have any of the suggested after-market solutions.
  8. tiztim
    49
    Chicago
    I put pics up for this: http://priuschat.com/forums/gen-iii-2010-prius-main-forum/68816-anybody-else-having-problem-3.html
  9. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I don't find the "blind spots" as referred here to be much different than any other car I have owned. I think each car is unique to them and you have to "learn" the car somewhat and then your cognizant of them. I have learned to adjust my mirrors in all cars to look at the farther distance (side view) not close to the body as was once taught to me...that helps, but I actually can see more out of the back than in my sedan vehicle which I traded. SO... more of a learning curve with each vehicle we drive.
  10. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I don't have blind spots, but it takes some getting used to the split view in the back with the spoiler. Fortunately it's a thin blockage of the view.
    If you lean to the left with your head close to your window and set your left mirror so that you just barely catch your car, then put your elbow on the console and adjust your right mirror so you just barely see your car you will notice as you sit straight that as a car or person moves behind you (or as you pass or they approach) the image will move along from the outside mirror, across to the rear view and then to the opposite side with overlap. This takes some getting used to because I believe 90% of the people usually have their mirror adjusted so that half of the view is nothing more than the side of your car, which you don't really need to view while driving.
