Gen 3 2011 sticky caliper? Hmmmm
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ianmeister, Mar 16, 2022.
  1. Ianmeister
    Ianmeister Active Member
    304
    311
    Meridian Idaho
    Hello all! So I’ve noticed something interesting. When I press down on the brake pedal all the way First the anti-skid light comes on. When I release the pedal the light goes off, and when I start to move the front caliper grabs and makes a loud “clunk”! When the wheel starts to roll. Do we have a sticky caliper that needs replacing? What say you all?
    also do I need tech stream to replace and bleed a caliper on Gen 3?
    thanks all!
    ps. Anyone who tells me to just go buy a new car will be unregrettably placed on my ignore list.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,160
    2,208
    Taylors, SC
    You might not have to replace the caliper. The brake caliper pins are likely corroded and frozen.
    Check out this video;
  3. ChapmanF
    15,560
    Are you certain that you are not engaging the hill-start assist (described in the owner's manual)?
    When you arm it (by pressing the brake pedal all the way), the skid light comes on with a short beep.
    The brakes then stay applied until you apply go pedal to move the car, and the brakes then let go.
    If you take your foot off the brake and do not apply any go pedal, the brakes should let go about two seconds later anyway.
  4. Mendel Leisk
    38,702
    Attached is non-Techstream instruction for brake bleed (plus Techstream bleed and basic brake inspection info), from 3rd gen Repair Manual.
    Some relevant links in my signature too.
  5. Ianmeister
    304
    311
    Meridian Idaho
  6. Ianmeister
    304
    311
    Meridian Idaho
    Ok. So it doesn’t matter if I engage the hill assist or not. Every time I stop no matter how gently I apply the brakes that caliper sticks and makes a pronounced “thunk” and jolt when I start moving again.
  7. Georgina Rudkus
    3,160
    2,208
    Taylors, SC
    Again, it is most likely "sticking slide pins." Check out this video.
  8. Ianmeister
    304
    311
    Meridian Idaho
    Well kids, I pulled the pins out of the calipers… it was actually very easy. You can pull and inspect them one at a time without actually removing the piston completely. Anyway they were clean and greasy. So I added a little more grease and reassembled. Strangely they don’t seem to be doing it anymore. We‘ll see.
  9. Mendel Leisk
    38,702
    What grease?
