Gen 3 After-Market Cat Converter Suggestions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by T T, Jan 8, 2025.
  1. T T
    T T Junior Member
    New York
    Hi guys,
    What after market catalytic converter do you guys recommend for a Gen 3? The original was stolen and a aftermarket one was put in. You guys know the story, the check engine came on and I couldn't pass emissions. I also tried a spacer with no luck.
    It seems like there is a permanent code when I run the scanner that can't be deleted. I can't get my system monitors ready to pass :/ I'm going to try a different aftermarket converter. Any suggestions or links to particular one that worked for you?
    Thanks!
  2. douglasjre
    douglasjre Senior Member
    2,087
    698
    Null, NL
  3. Tombukt2
    Tombukt2 Senior Member
    12,003
    2,123
    Durham NC
    Doesn't MagnaFlow make a unit for gen3???
  4. ASRDogman
    ASRDogman Senior Member
    7,114
    3,713
    I don't believe the aftermarket ones have the lines for the coolant.
    So it's NOT really for a Prius.
