Gen 3 Aftermarket Radio + Backup Cam Suggestions?
Discussion in 'Gen 3 Prius Audio and Electronics' started by PriusLady3, Oct 28, 2025 at 5:29 PM.
  1. PriusLady3
    PriusLady3 New Member
    Tuesday
    Hello! My 2013 Prius Two (bottom tier/basic model) touch screen stopped working about a year ago and I’ve debated on how to go about resolving the issue (new aftermarket radio, replace digitizer only, replace with pre-owned OEM radio). I’m leaning toward getting an aftermarket, in-dash radio receiver & having a new backup camera installed as well. I was thinking it best to order a package combo with radio & cam together to ensure compatibility. Ideally, given I’m not a bells & whistles kinda gal, I would like to keep the system itself as boring & simple as possible, although it seems like all the aftermarket options come with spiffy tech upgrades regardless. I’d like to keep the cost affordable, under $300 if possible (not including install costs - which I’ll probably call Geek Squad for).
    Any recommendations, suggestions, or insight would be greatly appreciated! Many thanks in advance!
  2. Tombukt2
    Tombukt2 Senior Member
    12,828
    2,306
    Durham NC
    LOok at crutchfield they used to be the folks . Getting your steering wheel buttons and all of that stuff to work on the proper can bus circuit can be quite an issue . Be very wary of the Amazon big screen sellers very. There are a few model for Gen 3 but you've to be very careful and it needs be returnable. Beware many sellers now the return window closes the minute they ship the product be very wary of those type sellers .
  3. Tombukt2
    12,828
    2,306
    Durham NC
    Have you had a bunch of work done on your Prius you bought second hand not long ago? . Beware of the other issues that could possibly be right around the corner before you go messing with the stereo would be my advice repairbills can be large .
    BiomedO1 likes this.
  4. ASRDogman
    ASRDogman Senior Member
    7,493
    3,882
    It would be smart to stay away from worse buy!
    Go to Crutchfield. They have a lot to offer, and can supply all the cable's your need to
    make it easy to install.
  5. BiomedO1
    BiomedO1 Senior Member
    3,361
    1,751
    SacTown, Ca
    IMHO; I'd replace it with a good used OEM unit - that Toyota CAN bus is the biggest issue here that may disable unknown functions. Newer car ECU systems are tightly interwoven by design. Keeps you coming back for more. Best course of action is to use a separate 9-10" low profile HUD, if you want modern functionality. It won't interfere with the car's basic systems and retain full OEM operations; no separate CAN bus alarm module or steering wheel interface modules.
  6. DirkAshburn
    DirkAshburn Member
    134
    56
    Virginia
    I 3rd Crutchfield. I replaced the stereo in my 2010 Mazda 3 with a Sony XAV-AX8100 in 2023. They told me exactly what I needed like the iDatalink Maestro to connect up the steering wheel buttons. All controls work perfectly, and the unit is a floating one which looks amazing in the car. I wasn't too hard to do, I think the hardest was getting to the factory Sirius XM to get the antenna cable off it to route to the new module I installed. The rest was pretty much plug and go.
    #6 DirkAshburn, Oct 29, 2025 at 1:04 PM
  7. Tombukt2
    12,828
    2,306
    Durham NC
    The Gen 3 is easy to get the radios for I had three of them here and couldn't get rid of them I didn't want 300 either.
  8. BiomedO1
    3,361
    1,751
    SacTown, Ca
    Do you know if those units incorporate a lock-code? If so how difficult or expensive is it to get around? I know some OEM boxes used to do that.
  9. Tombukt2
    12,828
    2,306
    Durham NC
    I don't think the generation 3 regular or even JBL radio have to have 7d matching or any of that I know of. You just buy and plug it in and it works it works.
