Gen 3 brakes, need shims & fitment kits?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kehyler, Apr 12, 2020.
  1. kehyler
    kehyler Member
    68
    26
    blah
    Hi All,
    I am going to be doing brakes on my Gen 3 Prius soon. I was thinking that the following parts might be reusable if in serviceable condition, so I'm interested in hearing from people who have taken theirs apart. Are the shims (between the pad & piston) and the fitment brackets (that the pads glide in) usually in decent enough condition that they can be reused?
    (Also, if I need them, would anyone happen to know if the kits below need quantity 2x or 1x?)
    Thanks,
    -kehyler
    Front "anti-rattle" kit
    Disc Brake Anti-Rattle Clip Set - Toyota (04947-42050) | Toyota Parts
    Front shims
    Disc Brake Pad Shim Kit - Toyota (04945-47020) | Toyota Parts
    Rear "anti-rattle" kit
    Brake Pads Hardware Kit - Toyota (04948-47010) | Toyota Parts
    Rear shims
    Brake Pads Hardware Kit - Toyota (04946-47070) | Toyota Parts
  2. The Critic
    The Critic Resident Critic
    3,193
    2,315
    CA
    This shims and fit kits (bracket clips) are reusable in areas that do not see snow or road salt. We usually bend the ears of the shims very gently (to make them fit better) and apply some Molykote M77 or CRC brake caliper grease to the shims before install.
    The fit kits (bracket clips), at least out here, are reusable after a cleaning with a small wired toothbrush. It is best to not remove them from the bracket if there are no rust issues in your area.
    Raytheeagle likes this.
  3. ChapmanF
    14,971
    The fitting kits are typically the only parts I've needed to replace on mine (Indiana, uses salt).
    Shims, pads, rotors, everything else last practically forever with regular inspection.
    The fitting kits are very slippery from the factory, with a dry coating, sort of like teflon.
    If that's worn off but the metal is still shiny and smooth, they're more or less ok.
    If they have rusted rough enough that the pad ears don't slide in them super easily, time for new ones. They're cheap.
    No grease there; just attracts grit.
    The Critic likes this.
  4. The Critic
    3,193
    2,315
    CA
    I have found that some shims will separate after a while. Usually by the 3rd brake job, you will find the Teflon layer on the shims start to peel off.
    Grease on the fit kit is subjective. A lot of people do it and use way too much. If I add any grease, I add a faint film to the ears of the pads only.
    But some OEM’s, such as Subaru, want the entire clip to be greased. In those situations, I just use a disposable HF paint brush and paint the thinnest layer possible.
  5. ChapmanF
    14,971
    I suppose the difference might be Toyota doing the dry Teflon thing instead?
  6. Mendel Leisk
    38,102
    I like to apply the anti-seize sparingly to the smaller of the two components that'll be in contact, gets it just in the contact zone. You'll still get a slight amount of "squeeze out" around the perimeter.
  7. ChapmanF
    14,971
    I don't mean to pick on anyone else's preferences, I just try on PriusChat to describe what Toyota recommends, unless I say I'm making a different recommendation and I say why. Because PriusChat readers have a right to know that.
  8. kehyler
    kehyler Member
    68
    26
    blah
    Thanks all.
    Would anyone happen to know if the kits below need quantity 2x or 1x? I'm not sure if the kits supply both sides (as the pads do) or one side (as the rotors do).
  9. ChapmanF
    14,971
    Pretty sure a shim kit and a fitting kit is both sides.
  10. The Critic
    3,193
    2,315
    CA
    One kit per axle.
  11. ChapmanF
    14,971
    'Axle' being 'pair of wheels at the same distance from the front of the car', despite the front 'axle' being two shafts, and the rear 'axle' being an H-shaped stamping with stubby hubs on two ends. :)
    2012 Prius v wagon 3 likes this.
