Gen 3 Dead accessory battery, manual key won't unlock door
Discussion in 'Gen 3 Prius Main Forum' started by cagemo, May 4, 2019.
  1. cagemo
    cagemo Member
    132
    california
    My 2014 Prius has a totally dead 12v battery. It unlocked normally with the fob last night but would not start, and didn't have enough power to re-lock the doors electrically. It was late at night, so I locked all the doors manually using the interior latches, thinking I could use the mechanical key to open the drivers door and work on it today. The mechanical key turns (clockwise, per the owners manual) but doesn't unlock the door. Searched the forums but can't find anything for this specific problem. Anyone have advice?
    #1 cagemo, May 4, 2019
    48,945
    the manual key locked it last night?
  3. cagemo
    cagemo Member
    132
    california
    No. I locked all the doors manually, using the mechanical interior door locks. The doors would not lock electrically, probably because the 12v battery is dead.
    #3 cagemo, May 4, 2019
  4. cagemo
    cagemo Member
    132
    california
    My essential question: Is the drivers side, outside mechanical key operated completely by mechanical forces, or is it electrical in any way? If it's all mechanical, then I just need to figure out what's seized up or not working properly.
  5. Patrick Wong
    18,198
    6,464
    I suggest squirting a little WD-40 into the mechanical key hole to see if that would help the mechanical key to rotate sufficiently to unlock the door.
  6. bisco
    48,945
    and try a pair of pliers on the key to aid turning, but don't bend or break it, wiggle it back and forth.
    yes, it is all mechanical.
    Colin Garcia, cagemo and Bay Stater like this.
  7. ASRDogman
    ASRDogman Senior Member
    5,893
    3,161
    I would use the key once a month or so just to keep it free of dirt and junk.
    The grease will harden over time, heat, cold, etc.
    Better safe than sorry...
  8. cagemo
    cagemo Member
    132
    california
    Thanks everybody for the advice, and confirming it's all mechanical. I had tried pliers carefully and rotating it back and forth but not the WD40. Can never find that red tube... Will try that and report back.
  9. bisco
    48,945
    hopefully, it's not disconnected inside the door. have you owned it since new?
  10. cagemo
    cagemo Member
    132
    california
    I wondered that too. But I have owned it since new.
  11. Grit
    Grit Senior Member
    6,111
    4,039
    Wilkes Land
    There's a website for that product.
    #11 Grit, May 5, 2019
  12. Grit
    Grit Senior Member
    6,111
    4,039
    Wilkes Land
    I use white lithium grease or the wd-40 rust & dust resistant line of dry lube. Regular wd-40 will get you trouble in the future.
    Johnny Cakes, Raytheeagle and bisco like this.
  13. ASRDogman
    5,893
    3,161
    When you get it unstuck, if it is, you should remove the door panel and lube the lock with graphite.
    Or whatever toyota calls for....
    Bay Stater and frodoz737 like this.
  14. bettergolf
    bettergolf Active Member
    411
    332
    Sanford NC
    Triple A can get in....they'll pry the door just enough to get a rod to the door handle and open it from the inside.
    Bay Stater and cagemo like this.
  15. frodoz737
    frodoz737 Top Wrench
    4,297
    2,347
    33
    ALWAYS use graphite, not WD.
    Johnny Cakes likes this.
  16. ASRDogman
    5,893
    3,161
    WD40 will loosen it up, graphite won't. So AFTER the wd40, clean up the lock and use graphite.
    kc5dlo and Bay Stater like this.
  17. frodoz737
    4,297
    2,347
    33
    Silicon and graphite combined do not make good bed fellows in a lock.
  18. Usle
    Usle Active Member
    317
    139
    Me
    2018 Prius Prime
    Lot's of ideas, the op disappeared, but....the op mechanically locked it from the inside, what's that?
    I'd contact toyota and ask, and keep calling dealers untill someone knows how to unlock when mechanically locked from the inside.
    Obviously the key isn't working, is there a sliding door or an incantation?
  19. bisco
    48,945
    what's what?
  20. Grit
    Grit Senior Member
    6,111
    4,039
    Wilkes Land
    Toyota will probably say they..."never heard of it." Just like all the other issues that's been reported to them with that usual answer :p
    spiralhelix likes this.
