Gen 3 DIY ATF Change Video?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaybird124, Sep 28, 2014.
  1. Jaybird124
    Jaybird124 Junior Member
    28
    Central Florida
    There was a fantastic DIY video of someone doing a drain and fill on a Gen3 Prius I saw a while back. I can't find it anywhere: PC, Google, YouTube.
    Anyone know the one I'm talking about?
  2. Jaybird124
    28
    Central Florida
  3. Mendel Leisk
    40,575
    Here's the repair manual info, if you haven't found already. Torque specs, qtys, etc:
  4. Prius_Boriqua
    Prius_Boriqua Junior Member
    38
    17
    Phoenix, Arizona
    Its really simple. Just take your time. Make sure to loosen the top bolt first (where you will fill the oil to level) before taking the bottom bolt off. Last thing you want to do is to drain your oil and not be able to remove the top bolt to fill it up. The Manual says something like 3.5 quarts to fill. Mine took about 3.75 quarts with the car perfectly level. Some people say they used the entire 4 quarts. This might not be your case but if it is don't worry. Just make sure your car is leveled.
