Gen 3 EV Mode question
Discussion in 'Gen 3 Prius Technical Discussion' started by seasidetraveler, Nov 29, 2010.
  1. seasidetraveler
    662
    CA
    I was under the impression that when you enable EV mode the car will stay in EV till around 40 mph or something close to it? I can't seem to go above 10 mph without getting a message stating "EV Mode disabled due to excessive speed"? Is this a glitch or can you really only go 10 mph? That seems pointless if that is the case lol
    Do I need to be at a certain battery level or something?
  2. wrexed03
    wrexed03 New Member
    42
    Melbourne Australia
    Mine maxes out at 47kmh then ice kicks in. 60kmh would have been nice but its the way its been configured from factory. This is an aussie speced vehicle not sure about yours.
    Regards
  3. vday
    vday Member
    312
    Israel
    The car needs to be fully warmed up and the battery with 5-6 lines or more to get max speed. Even then you can not accelerate to fast
    Danny
  4. fuzzy1
    10,602
    As vday stated, the car must warm up before allowing EV at higher speeds.
    When the engine coolant is below 68F, it won't go into EV at all.
  5. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    EV mode is only good for up to 25mph if your engine is warmed up and you have 4-8 bars. You can accelerate to 25mph in EV if your HSI stays with in ECO bar. You can accelerate to 40+mph in Normal mode or ECO mode if your engine is fully warmed up and have 6-8 bars without turning on the ICE. The HSI may not pass the halfway point. Once you pass those points, it will kick you out of EV and the ICE will kick on. The best electric acceleration I did was when the battery had 7 bars. I got up to 42mph in .4 miles before I couldn't accelerate faster. I was down to 4 bars. On a side note, When you have 6 or more bars, you can maintain 40-43mph in electric only while the ICE is off for at least 1 mile. The longest electric distance I've driven is 2.7 miles.
  6. wrexed03
    wrexed03 New Member
    42
    Melbourne Australia
    Strange i can put mine in ev mode straight away from cold. Will try it again in the morning and re confirm..
  7. vday
    vday Member
    312
    Israel
    If you press EV fast (after the ready light goes on) it will go in even when the engine is cold - It will stay in EV at very low speeds
  8. wrexed03
    wrexed03 New Member
    42
    Melbourne Australia
    I can confirm this is correct. I did it this morning when i left for work with a cold engine and again in the afternoon heading home.
    Hit the start button to go to ready status then press ev mode button and your done.
  9. fuzzy1
    10,602
    I note that these reports, and other similar ones (e.g. Kithmo in Can you put a Prius in Neutral without turning it on?), come from non-U.S. models.
    U.S. models seem to be different. See my several posts in Can I start and move in EV mode? (that series ran over 100 tests) and EV cancelled due to high speed while doing single digits MPH?
  10. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    As someone has already stated, EV mode is more restrictive on the US spec cars compared to the Euro, Jap or Aussie spec models.
    I think this is due to differing emissions legislation. Also, US spec cars seem to display the correct speed on their speedo whereas Euro cars for example will overread by about 5 mph or so. Eg my car switches EV off at an indicated speed of 31 mph whereas the US posters indicate that EV switches off at 25 mph. Presumably the same speed in reality.
  11. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I think US models are restricted more to prevent wearing out batteries during the 8 year warranty period! In any case, if you drain the battery the engine is just gonna have to work harder to recharge it, negating any savings you got running that mile in EV! Of course, if you got a big hill to regen on at the end of the EV cruise, go for it!
  12. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    We have 8 year warranty on the HV batteries here in the UK plus the 'normal' warranty on the car is 5 years/100k miles.
    I understood your restrictive EV use is due to emissions in that the car must warm up the emissions systems earlier than required here and also keep emissions lower when switching on the petrol engine when the car kicks out of EV mode (ie excessive speed).
    I could be wrong though - :confused:
  13. daniel
    14,487
    1,519
    Spokane, WA
    My experience is with my 2004 Prius, but I imagine it's probably similar:
    EV mode does not allow hard acceleration. To accelerate to maximum allowable speed you must do so VERY gently. Merely maintaining speed up a hill can be too much for EV mode, and the engine will kick in.
    When you turn the car on, the engine does not start immediately unless you hit the pedal to accelerate immediately. In my 2004 the delay is about 10 seconds. During that ten-second period you can put the car in EV mode, and as long as you accelerate gently enough, you can drive in EV mode until the battery reaches a set level. This allows the car to be moved short distances, or driven out of a residential area without running the engine.
    However, once the engine starts, it will go through a warm-up period before EV can be engaged.
    Note that under most circumstances it is inefficient to drive more than a short distance in EV mode, since the engine must recharge he battery later. An exception would be if you are approaching a long downhill. In extreme cold weather, when the car is reluctant to stop the engine, and the battery becomes full, you can use EV mode to draw it down a little, but you should not draw it down much before allowing the car to regulate itself again.
  14. ETC(SS)
    7,334
    As I stated on an earlier thread, I haven't found the EV mode to useful in any way---except if you want to sneak up on your neighbor's cat....and the tire noise always gives you away, so it's not much good for that either.
    I guess if you wanted to move the car w/o starting the ICE (for whatever reason) it's OK for that, but I've read posts from the hypermilers that pretty much poo-poo EV mode for increasing your lifetime fuel economy. It was cool to try to play with for about 30-seconds, but then I got over it.
  15. Tideland Prius
    16,611
    Note that there are two limits.. 10 and 20mph (16km/h and 30km/h) for the lower limit and 25 and 32mph (40km/h and 50km/h) for the fully warmed up limit
  16. Former Member 68813
    3,524
    983
    US
    I find EV very useful to go in and out garage without unnecessary engine starts and wasting fuel to warm it up for nothing. Too bad this feature works only during summer here in US.:mad:
  17. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    It is now, as from June 2010, but prior to that from the UK launch in 2009 to end of May 2010, it was 3 years normal warranty (car) and only 5 years on the hybrid system, which is what I have, as I bought mine in May 2010 :(
  18. fjpod
    fjpod Member
    419
    72
    New York
    Not sure if somebody said this already...but as per my scan gauge, EV mode will stick up to 24 mph with your foot on the accelerator past the midpoint on the HSI, as long as the engine coolant is at 159F or so...OTW, it drops out at 10 mph. ICE kicks on past 44 mph no matter what. Heavy acceleration will kick the ICE on at any temp or speed.
    Gen 3 of course.
  19. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    All of you that are realy interested in warm-up stages, just read the first sticky thread (by Ken@Japan) of this forum!
    Giora.
