Gen 3 Heat Exchanger Repair
Discussion in 'Gen 3 Prius Technical Discussion' started by doriopsilla, Feb 22, 2025.
  1. doriopsilla
    doriopsilla New Member
    San Diego CA
    Our 2011 Prius (185.,000 miles) is running through coolant quickly. It's not the head gasket, so that would seem to indicate a leak in the heat exchanger. Replacing it is prohibitively expensive. I recall, in the old days, if you had a leaky radiator you could add powdered-metal Stop-Leak to the coolant and sometimes plug the leak that way.
    I don't know anything about the design of the heat exchanger. Would something like Stop-Leak fix most of the leaks you would find in the exchanger? Has anyone tried that? It seems like a cheap way to attempt to fix the problem, and if it doesn't work the bypass option wouldn't be that much more expensive.
    Of course, if someone was to steal the car's cat converter assy then insurance would cover the replacement.
    Thanks!
    George
  2. BiomedO1
    BiomedO1 Senior Member
    4,047
    2,132
    SacTown, Ca
    IMHO, I would NOT use any stop-leak products in modern automobiles. As our ability to manufacturer finer and more precise parts, cooling system heat exchangers passages has gotten much smaller and narrower. The product you mentioned hasn't changed in four decades and is more likely to clog your cooling system, causing an overheat issue in the warmer parts of the year.
    The bypass is your best bet and hopefully it'll pass smog that way.
    Good Luck.....
    Brian1954 and ASRDogman like this.
  3. Paul Gregory
    Paul Gregory Senior Member
    2,223
    590
    Alberta
    2024 Prius Prime
    XSE
    I memory serves, the heat exchanger has a thermostatically controlled bypass to prevent the coolant boiling out.
    It it possible that this has malfunctioned?
  4. ASRDogman
    ASRDogman Senior Member
    7,787
    3,974
    You should do a pressure test to find the leak. Then you can know for sure where it is leaking.
    NEVER USE THE ANY STOP LEAK OR HEAD GASKET SEALER!!! It WILL ruin all the coolant
    system, including thermostat and coolant pump.
    BiomedO1 and Brian1954 like this.
  5. Brian1954
    Brian1954 Senior Member
    2,383
    957
    South Central PA, USA
    The Gen 3 Prius has had very few problems with the exhaust gas heat recovery system. It is a big problem only on Gen 4 Prius. I would be very surprised if this is your problem.
    Has the high coolant temperature warning light ever come on, even for a few seconds, while driving up a hill or at highway speeds?
    My guess is that the engine water pump is starting to fail, and there is not enough coolant flowing through the engine. When this occurs, the engine overheats and coolant is forced out the overflow on the plastic reservoir. Look very closely around the reservoir for evidence of dried coolant.
    You should purchase an OBD2 Bluetooth dongle and use an app on your phone to monitor the engine coolant temperature. Or you could purchase a display unit that plugs into the OBD2 port to monitor the coolant temperature. I use a P10 display. Normally, the coolant temperature will not go higher than 202F.
    Do a search on this Gen 3 forum about engine water pump going bad.
    #5 Brian1954, Feb 22, 2025
    BiomedO1 likes this.
  6. Mendel Leisk
    41,845
    How certain are you? Who did the diagnosis? What method(s)? Head gasket failure by your miles is VERY common.
  7. doriopsilla
    San Diego CA
    Mendel:
    My daughter took it to a mechanic and they did a compression check on all the pistons. They detected no pressure issues there. There is also none of the tell-tale white fog from the exhaust pipe. That is why they suspect the heat exchanger. Given the issues with some Prius where the head bolts strip, I was glad to hear it's not the head gasket. My friend's Prius had a bad head gasket and when the took the head off to replace it, they found the bolts were stripped and they couldn't reassemble the head.
  8. ASRDogman
    7,787
    3,974
    Did they do a coolant pressure test???? It is VERY SIMPLE to do.
    “IF” they know what they are doing, they WILL put pressure on the coolant system,
    then us a bore scope in each spark plug hole and see if coolant leaks into the cylinder.
    99% of the time it’s between the #1 and #2 cylinders.
    It is extremely rare to see the steam out the exhaust in a Prius, because by then,
    it’s so bad there is no doubt what it is and the engine is very noisey and you’ll have no power.
    Usually it start very slowly, then gets worse.
    Ask them if they did a coolant pressure test, and if no, ask them to do it. Or find another place.
    It does HAVE to be a Hybrid shop, the coolant system works the same as non hybrid cars.
    Brian1954 and MAX2 like this.
  9. Mendel Leisk
    41,845
    That reminds me of the time we had a brake issue, with an Accord. Every time you stepped on brakes it sounded/felt like the car had a broken pelvis or something. Seemed to be emanating from front/left corner, so I removed that wheel, and oh-hoh: a crack on the brake rotor.
    I called dealership, told them the issue, booked appointment, got it in.
    about an hour later got a call, something like: “your cars ready, we’re just giving it a wash, and there was no problem with the brakes”.
    I was relieved, for about a second. Then I told them to have another look. And contacted the service manager. Things got back on track then.
