Gen 3 Prius air vent output is weak compared to Gen 2
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusroadtrip, Aug 5, 2020.
  1. priusroadtrip
    priusroadtrip New Member
    SF Bay Area, CA
    Hello-
    I recently purchased a 2011 Prius coming from a Gen 2 Prius and it seems that the car's air vent output is much less and not as efficient as the previous Gen 2 Prius I had. On the Gen 2, I used to run with just the vent open and maybe at the lowest setting and it heats and cools the car pretty efficiently. I feel like I have to have the air speed set at closest to the highest setting in the Gen 3 to have the same output. Any thoughts on this? Thanks!
    49,467
    have you replaced the cabin filter/checked the fan?
    is it one vent or all?
    are you using eco, normal or power mode? gen 2 doesn't have this option which reduces hvac power usage
  3. priusroadtrip
    SF Bay Area, CA
    Thanks bisco for the response. Yes I replaced the cabin air filter and there was no change. The air is coming out of all of the vents and it increases when I increase the speed but it just doesn't seem as efficient as the gen 2. Is there a way to check the fan.
    I've only run it in normal mode only.
    49,467
    with the filter out, you can look at the fan with a mirror i think, and run through the speeds listening to the sound change.
    maybe you need to clean the intake, it's a bit complicated, under the ww wiper. there should be a thread here describing the dismantling.
    any difference between fresh air and recirc?
