Gen 3 Prius Battery Fan Operation
Discussion in 'Gen 3 Prius Technical Discussion' started by Shady Ghabboun, Jul 26, 2021.
  1. Shady Ghabboun
    Shady Ghabboun New Member
    Amman
    Hi everyone,
    I have a question about the operation of the Hybrid Battery fan in the Gen 3 Prius (2012 to be exact), so I was monitoring the fan for some time and I noticed that even when the fan is on mode 6 it actually does not work at the same mode until I start moving the car (when I am stationary the fan does not operate while the temperature is also high "above 121 degree" and once I start moving the fan starts working and the fan speed depends on the car speed) I don't know if this is odd or normal, and I wanted to check with you if this case is normal or in case there is a problem with the fan (I have used techstream to operate the fan manually, and it actually operates immediately not like when it is in automatic mode)
    Sorry for the long post and thanks in advance.
    Best Regards
  2. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    I've not seen any evidence of its operating speed being based on vehicle speed... But it does have relays and a complicated method of slowly speeding up that can be frustrating when trying to diagnose it.
  3. Shady Ghabboun
    Amman
    Thank you for your answer, I noticed that it actually does increase slowly when you set it manually however it does speed up somehow immediately, however in my case the car is actually only operating on Gas while the battery is so hot, and the fan does not operate, or operates when the car is moving, do you think this means a faulty Fan ?
  4. PriusCamper
    11,055
    4,498
    If the fan is not working properly you should get an error code and a warning light... If you don't have that I wouldn't worry about it. You can independently monitor battery temps via Dr. Prius app using one of these: Hybrid battery diagnostic and repair tool for Toyota and Lexus
  5. Panicos
    Panicos Junior Member
    38
    16
    Cyprus
    Same here. When the car is parked with the engine ON, (and AC On) the battery temperature rises, and the fan does not turn On unless you drive it above 25mph (i think). Thats when the barrery starts cooling off. (i have a thermometer to monitor the temperature). SOOOOO Toyota made a mistake or on purpose so we damage the batteries with heat etc.
    The fan should turn On when the betteries heat up.
    I would line to find a way to make the fan work without having to drive about...
  6. ChapmanF
    15,433
    Could either or both of you post some further details of your monitoring setup, and the logged data if any?
  7. Noahdoge
    Noahdoge Active Member
    165
    119
    Mississippi
    Get the Dr. Prius app and the proper obd-2 scanner. With the app in special features you can override the fan temperature to something much lower like 85 degrees. My 2012 Prius does the same thing where the fan does not really kick on until I’m driving above 25 mph, but if you put your ear up to in while stationary you can hear it pulling a little bit of air in but it’s very quiet.
  8. brightRAEofsunshine
    brightRAEofsunshine Junior Member
    Mojave,CA
    this video goes into some detail. It is for an app called Hybrid Assistant, and explains temperature limits and efficiency.
  9. douglasjre
    douglasjre Senior Member
    1,856
    647
    Orlando, FL
    I don't intend to be running an app in my phone in the background every time I drive. Is there a way to reprogram the car to set the fan temperature limits differently?
  10. rjparker
    rjparker Tu Humilde Sirviente
    7,917
    4,678
    Texas Hill Country
  11. Noahdoge
    165
    119
    Mississippi
    I did it through the Dr. Prius app “special features”. Also disabled the reverse beep and seatbelt beep. I set my fan to come on at 70 degrees.
  12. rjparker
    7,917
    4,678
    Texas Hill Country
    That only works as long as Dr Prius is running and connected to the obd2.
    #12 rjparker, Jun 29, 2023
    douglasjre likes this.
  13. Noahdoge
    165
    119
    Mississippi
    When I’m connected, my fan runs constantly at usually the highest speed. But I noticed a difference after changing the setting last year and in the spring and fall time I can actually hear the fan running (without being connected) when before using Dr.Prius I’d only hear my fan kick on in the summer time. Also before changing that setting in the app, during the hot days in the summer the fan would turn on the highest setting for maybe 10 minutes during a long trip, now it stays consistently on during long trips (also without being connected).
  14. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Disabling the back up beep was the FIRST thing I did when I set up Techstream!
    I have the xtool D8 now, and it sure seems easier and FASTER!
    Noahdoge likes this.
  15. douglasjre
    1,856
    647
    Orlando, FL
    Parker? Can u help me here?
  16. rjparker
    7,917
    4,678
    Texas Hill Country
    I would suspect high battery temps and an engine running when it should not be means a failing hv battery or a clogged blower wheel.
    I watch engine coolant temp over battery temp. However I have rarely seen battery temp much over 100f.
    Even though I live in an extremely hot environment and drive high speed highways most of the time, I have never used hybrid fan control strategies or had issues with the hv battery overheating. I am also on the IOS platform so can't use Hybrid Assistant.
    My method is to park in a garage most of the time and run the ac at 75f constantly when driving. No pets in the car has kept the battery fan blower clean enough, I don't think I have ever heard the fan ramp up. Of course a v wagon has the intake duct under the rear seat which probably muffles it somewhat. The v also has higher capacity ac.
    I have documented charging voltages around 13.4 vdc in Drive immediately going to 14.4 in Park. Why I am not sure but perhaps it has some effect on the battery fan. Doubtful and does not make good sense but the charging voltage change in Park is very repeatable.
    #16 rjparker, Jun 30, 2023
  17. Noahdoge
    165
    119
    Mississippi
    Where did you get that digital temp display? I’d love to have that. Also being in South Mississippi/Alabama we have been in the 115 degree heat index this week. Also 80-90+% humidity. The highest my battery has ever got was 145 degrees. But usually I’m able to keep it around 95-105 running Dr Prius.
  18. rjparker
    7,917
    4,678
    Texas Hill Country
    P10 link with unit shown before configuration. At this price it might be a close out on this model.
    #18 rjparker, Jun 30, 2023
  19. douglasjre
    1,856
    647
    Orlando, FL
    If I use the Dr Prius app to change the parameters can I then remove the dongle and it'll still have its effect on my settings?
  20. Brian1954
    Brian1954 Active Member
    789
    299
    South Central PA, USA
    See post #12 for the answer to your question.
    #20 Brian1954, Jun 30, 2023
