Gen 3 Prius miles per tank
Discussion in 'Gen 3 Prius Fuel Economy' started by Padraig, Oct 4, 2019.
  1. Padraig
    Padraig New Member
    Ireland
    Hi
    In regard to a 2010 Prius. How many miles are you getting from a fill?
    I understand the tank is 45 litres, how far would this get you roughly?
    I’m not talking about getting the tank go nearly empty, just sensible stuff with about 5 litres left maybe.
  2. Tideland Prius
    16,623
    It is 45 litres. The low fuel light comes on at 35 litres in North America. In the summer, I can get about 500 miles/800km. In the winter, it’s about 400 miles or 640km (part of that is also because I refuel sooner)
  3. fuzzy1
    10,603
    But just 5 liters left IS nearly empty, by all common standards on this forum. It is far beyond the very last low fuel warning, and not enough fuel left to get to the next available fuel station in numerous parts of the western North America.
    The best Gen3 (2010-201) low fuel tests on this forum are described in the very first post of this very long thread, though you will need to convert from US to metric units:
    [WARNING] Running out of gas (Gen III) | PriusChat
    [​IMG] [​IMG]
    [​IMG] [​IMG]
  4. Padraig
    Padraig New Member
    Ireland
    Ok fair enough. Forget about my comment so about the 5 litres thing.
    Roughly how much do ye get from a tank?
  5. Mendel Leisk
    41,948
    You don't need an opinion poll on this, just do the math: figure out your fuel economy, for a tank or two, then armed with that, figure out how you'd get on 40 liters, or 35 liters, whatever you're comfortable with.
    fuzzy1 likes this.
  6. Padraig
    Padraig New Member
    Ireland
    Hi. I don’t have a Prius yet. I’m deliberating if I should buy one and was wondering roughly what people get out of a tank
  7. Mendel Leisk
    41,948
    Guesstimate you could use for fuel economy:
    5 liters per 100 kms
    47 mpg US
    56 mpg IMP
    (realistic, mixed driving)
  8. Padraig
    Padraig New Member
    Ireland
    Good call. So maybe around 800km per tank. That is decent.
  9. Tideland Prius
    16,623
    Yup. (see post 2)
  10. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    We typically refuel at 500 miles +/-50. A rule of thumb I read in some PC thread was to take the average MPG displayed on the multi-function display and multiply that x10 to set the point at which you should stop and refuel. The reason that is a reasonable rule of thumb, is that the fuel tank is 11.9 US gallons, and thus if the consumption estimates are correct, you have a 1.9 gallon safety margin.
  11. bisco
    52,417
    can you manage your way up to a 2012 plug in prius?
  12. Padraig
    Padraig New Member
    Ireland
    No. Is this linked with more miles per tank ?
  13. bisco
    52,417
    no, i have no idea why i asked that. must have been the Guinness :oops:
    Grit and Padraig like this.
  14. Randy Arteaga
    Randy Arteaga New Member
    Saint peters
    hello, i am new to this so hopefully i am doing this correctly. I have a question about my Prius. The tank hold 11.9 Gallons and i see a lot of people say that get anywhere from 500-600 on a full tank. Gas prices here are not bad and i always try to fill my tank up. Always caps me around $20-$25 on a full tank but my mileage goes only about 350-375. Today i put some gas in and decided to go cheap and go to the nearest cheapest gas station and it spent only $15, figured it'll maybe do a difference but still i only got 375 miles on full tank. now my question is, Is this normal over time or should i be getting 500-600 miles to a full tank of gas?
  15. fuzzy1
    10,603
    Dollar$ per tank doesn't help us provide a good answer. Some people are getting gas for under $2/gallon, when others must pay $4/gal. Please tell us how many gallons you are putting in for your refills.
    Also, the 11.9 gallons per tank spec applies only if you run it dry, forcing the car to roll to a stop. Normal drivers don't do that, it is unpredictable and terribly inconvenient at best. Please tell us how low you are running your fuel gauge. Some people refill when 3 or 4 bars are still showing, while others wait until the bottom bar starts flashing, then go another 50-100 miles. These differing groups get very very different miles per tank, even when they are getting the exact same MPGs.
    Also, tell us what your dashboard MPG display reads, resetting it at each refueling. This number is a fiction, reading a bit higher than your true MPG, but is close enough to be a good starting point.
    And for best feedback, don't give us coarse rounded numbers from memory, that just hides too many issues. Keep a fuel log, in a paper notebook or a phone app or other convenient recording means, and give us your actual fuel pump and trip odometer readings.
    If you are not getting over 50 MPG, and/or not running the fuel gauge past the low fuel warnings (flashing bottom bar, followed soon by Distance To Empty = 0 miles), then forget about the idea of 600 mile tanks.
    #15 fuzzy1, Nov 24, 2019
  16. Mendel Leisk
    41,948
    By the time he does all that, he won't be having the questions. :whistle:
    Maarten28, jerrymildred and fuzzy1 like this.
