For Sale Gen 3: TRD springs and TRD rear sway bar So-cal
Discussion in 'Private Sales' started by x-tnsiv, Jan 31, 2021.
  1. x-tnsiv
    x-tnsiv Junior Member
    socal
    2014 Prius Plug-in
    Selling a set of TRD springs and rear sway bar.
    the end links on the rear sway bars will need to be replaced. You can either go with OEM, or aftermarket. Someone on this forum used Moog end links (you can search this forum)
    I bought the springs used myself, so unsure of the actual mileage. But never had a chance to mount the sway bar.
    $225.00
    Local pick up only.
    located in Irvine
    Majestxc likes this.
  2. x-tnsiv
    socal
    2014 Prius Plug-in
    Pics of the springs installed on my old car
  3. m3pare
    m3pare Senior Member
    656
    1,813
    SoCal (626)
    Specs on TE’s?
  4. x-tnsiv
    socal
    2014 Prius Plug-in
    16x7, but I’ll need to re-check the offsets and get back to you.
  5. priusgreymint
    priusgreymint Member
    93
    67
    How much for rear sway bar only? I am in Irvine as well
  6. Nate9412
    Nate9412 New Member
    Riverside
    I’m interested if still available
  7. x-tnsiv
    socal
    2014 Prius Plug-in
    Sorry, the rear swaybar was sold.
    The Prius Plus Lowering springs are still available.
  8. Nate9412
    Nate9412 New Member
    Riverside
    How much for the springs?
  9. x-tnsiv
    socal
    2014 Prius Plug-in
    I can do $100 picked up.
    Or buyer pays shipping if necessary
  10. Joele3
    Joele3 Active Member
    108
    181
    Bay Area
    Raytheeagle likes this.
  11. Mongiamc10
    Mongiamc10 Junior Member
    66
    22
    I’ll take them if no one has picked them up yet.
  12. x-tnsiv
    socal
    2014 Prius Plug-in
  13. x-tnsiv
    socal
    2014 Prius Plug-in
    Message me if you’re still interested. Thanks.
  14. Majestxc
    Majestxc New Member
    Los Angeles
  15. Mongiamc10
    66
    22
    Sorry for the late reply. I am not on here much. Are they still available?
  16. x-tnsiv
    socal
    2014 Prius Plug-in
    Springs are still available.
  17. Mongiamc10
    66
    22
    Okay thanks. In the pictures of your evhicle with the springs installed, the rear seems to be lower than the front. Is that just due to your car on the incline or do you remember there being a noticeable difference from front/rear?
  18. x-tnsiv
    socal
    2014 Prius Plug-in
    I believe that’s how they engineered the springs to sit. I’m pretty sure there is naturally a larger fender gap on the front to accommodate suspension compression with the wheel turned.
  19. KamiKKazi
    KamiKKazi New Member
    OC
    Still have the springs?
  20. x-tnsiv
    socal
    2014 Prius Plug-in
    Yes I do.
Loading...
