Gen 3 Valve Cover Gasket Replacement Guide?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pingd, Sep 30, 2019.
  1. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Wonder if anyone is aware of a good, hopefully step-by-step guide on how to replace the valve cover gasket?
    I poked around here and on youtube ... maybe I'm just a bonehead ... but nothing is standing out.
    [This will be my next task after I get that %$&%##@! EGR cooler out!]
    I have changed simple ones, like an old Corolla and RAV4 ... the Prius has a lot of extra connectors!
  2. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    Just watch the headgasket video. They take it off at the start and put it back at the end. Add the repair guide and it’s pretty easy.
    -Spiral
    pingd likes this.
  3. spiralhelix
    255
    217
    Illinois
    -Spiral
    Montgomery and pingd like this.
  4. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Spiral - Thanks Kindly Man - clever - that saved me a lot of time and uncertainty!
    It might even make it easier to get the EGR cooler off (a little more room to work in I reckon).
    Man! It took him like 5 mins what will take me an hour I'm sure... lol
    #4 pingd, Sep 30, 2019
  5. spiralhelix
    255
    217
    Illinois
    Nah, 45 min lol.
    They also don’t show removing all the wiper stuff and cowl.
    Just be careful you don’t drop any bolts. That will add 15-20 min finding them
    Later.
    -Spiral
    pingd likes this.
  6. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Spiral - prudent and thoughtful advice again!
    With my luck I'll drop something into the valves and forget about it ... wrecking the engine that way ... going to have to make a cover (even if it is just a sheet or cloth towel or plastic wrap or ...).
    The other day I convinced myself I had a pair of mid-length, angled needle nose pliers with orange handles.
    Turns out I don't but had seen it so many times in the NutzAboutBolts videos I spent like 20 mins looking for them! ha ha ha!
    Some things are harder won than others, eh?
    #6 pingd, Sep 30, 2019
  7. Mendel Leisk
    41,865
    Torque values in the attached:
  8. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    Thank you kindly again Master Jedi Mendel Leisk!
    Am I reading it correctly ... if it states "10 (102, 7)" I should decode it as "10mm bolt head size and 7 ft-lbs torque (with no anti-seize)"?
  9. Patrick Wong
    18,210
    6,512
    No, the 10 is a reference to 10 Newton-meter torque spec. See the note at the lower left corner of the page.
  10. Mendel Leisk
    41,865
    Yes. 7 foot pounds is getting pretty low, below bottom threshold of many 1/2" or even 3/8" torque wrenches. And torque wrenches tend to be least accurate near their extremes.
    A 1/4" drive wrench, typically calibrated in inch pounds might be better, the value would be 7*12=84 inch pounds.
    I used to just wing it with the valve covers with previous Hondas, but it doesn't hurt.
    One trick I'd do for maintaining low torque is to one-hand tighten with a ratchet wrench.
    pingd likes this.
  11. Mendel Leisk
    41,865
    Yeah regarding the "10": read grasshopper, it says somewhere what the three numbers are. (y)
    pingd likes this.
  12. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
  13. Mendel Leisk
    41,865
    Setting up valve clearances on our fleet of Hondas over the years, I rarely changed any of the gaskets, only if they were brittle.
    That said, if this is once-in-a-blue-moon, and they've been in there a long time, yeah it's a good idea. But it's not obligatory; they don't self-destruct when you pull the valve cover off.
    pingd likes this.
  14. The Critic
    3,193
    2,333
    CA
    When I did my head gasket replacement, the valve cover gasket felt brand new. But those two small gaskets were extremely hard, especially the small o-ring. The small o-ring will stick to the valve cover as well; I almost missed it.
    pingd, SFO, Raytheeagle and 1 other person like this.
  15. Mendel Leisk
    41,865
    Yeah, as warranted. And I guess that's where that gasket rebuild kit comes in handy: you're getting the head gasket, plus pretty much every rubber piece under the sun, so you might as well use them.
    Too, with the old Accords, prying the valve cover off was relatively trivial event, every two or three years at the longest.
    Raytheeagle and The Critic like this.
  16. The Critic
    3,193
    2,333
    CA
    I have attached a picture with the gaskets circled.
    Those two gaskets tend to be very hard and must be replaced whenever the valve cover is removed.
  17. Mendel Leisk
    41,865
    Nice picture! Those tubes direct oil over the cam lobes I guess?
  18. pingd
    pingd Member
    97
    61
    Twin Cities, MN
    SUMMARY: In finishing this replacement, I believe there are an additional 3 gaskets/seals not mentioned.
    Total 4+2+1+1+1=1=10:
    4 spark plug tube seals
    * 2 small o-rings (internal to the 2 devices that attach to the top of valve cover)(see attached pic)(sorry, I don't know their names!)
    1 tiny o-ring (see The Critic's' pic above)
    1 three hole o-ring (see The Critic's' pic above)
    1 valve cover gasket
    * 1 valve cover bolt gasket/grommet (for that one LONG bolt in the "center" of the valve cover)
    [ * = not mentioned in this post yet ... see red circles in attached pic]
      File size:
      28.8 KB
    The Critic likes this.
  19. mohd farid
    mohd farid Junior Member
    malaysia
    can u share the youtube to me..im not be able to open it. Thanks
