Gen 4 12 Volt battery.
Discussion in 'Gen 4 Prius Technical Discussion' started by padroo, Feb 13, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,252
    I know the 12V Battery has been discussed before but this thread I don't want to talk about problems that peoples battery have had but what is a suitable replacement assuming you don't want to go to Toyota to pay their ransom.
    From what I have found it looks like the battery out of a Chevrolet Spark will fit and work.
    Here is some information/
    BCI Group Size: 140R battery 13-17 Chevrolet Spark
    ACDelco® LN1AGM - Professional™ Battery
    Toyota did it to us again by installing a non standard battery.
    A group 21 is a close match also and NAPA has a battery that they say is a direct fit.
    Battery - NAPA THE LEGEND - Professional - OE Exact Fit 12 Volts Group 140R 445 CCA Top Post
    https://www.napaonline.com/en/p/NBP75140R
    The information I have says my 2016 Prius has a conventional lead acid battery and not the AGM battery other years have had. There is no vent feature because it is under the hood.
    DonJuan1943 and Mendel Leisk like this.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    A "conventional" wet cell battery does vent, usually directly through a baffled cap where water is added.
    An AGM still is a better choice for a replacement........unless maybe you just want to get it ready for a quick sale.
    An OEM conventional wet cell can be replaced with anything that fits the available space and has a similar Amp-Hour capacity. In a pinch, even something smaller with less capacity.
    IF......your '16 already needs a battery, that should be a good clue that a conventional wet cell type will not last as long as an AGM in similar circumstances.
    #2 Sam Spade, Feb 13, 2018
    52,375
    what is toyota's list price on the oem? i thought they bragged about moving it under the hood to make the size more conventional.
  4. padroo
    2,763
    2,252
    No my '16 only has 1400 miles on it. 12 volt batteries have been such a big issue this winter I was just curious what was out there.
    I am not partial to AGM or a conventional lead acid battery but I am partial to my money.
    When they moved it under the hood didn't really make much difference in some ways, they used another odd ball size battery that so far I can't find in any of the size groups. They want you to buy their battery.
    I had a Mercury one time that came with TRX tires and wheels. It was an oddball size rim and you could only put a specific tire on that rim unless you changed the whole wheel. Moral of the story, Toyota doesn't play well with others.
    I always like more than one option.
    I am open to opinions on these batteries as suitable replacements. I have not tried either one so it isn't a done deal.
    RCO likes this.
  5. Prodigyplace
    12,670
    11,829
    Central Virginia
    I remember seeing it met some Japanese standard but most of their sales are outside Japan.
  6. Mendel Leisk
    41,889
    I don't see any hold-down brackets, not conventional ones the kind that can adjust for height. And there's a ledge along the right side, and the posts are recessed in pockets.
    Visual aid, a pic I snapped at our dealership. Wish I done better with the exposure, the label is blown-out:
    When you enter 2016 Toyota Prius it says it's not compatible, but that could be shortcoming of their website? It certainly looks very similar.
    The AC Delco was mentioned by @Elektroingenieur I believe, which probably means you can take it to the bank, lol.
    I think this thread should be pinned btw.
    #6 Mendel Leisk, Feb 13, 2018
    PtPri, wsncguy and bisco like this.
  7. padroo
    2,763
    2,252
    Looks similar to the Chevy Spark Battery. I don't know why the area is raised on both of them.
    It is held down at the bottom with the little ledge that stick out.
    Another thing I learned when you talk about "Group Size", this is a North American thing and even though it says international I don't thing it really is. It doesn't look like the Japanese follow this protocol.
    What are Battery Group Numbers? - UPS Battery Center
    #7 padroo, Feb 13, 2018
    RCO and Mendel Leisk like this.
  8. bisco
    52,375
    confound them!:mad:
    Norm from GA and RCO like this.
  9. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Has your battery shown signs of failing? I would have thought it would last a long time, seeing it isn't required for cold-cranking etc.
  10. Prodigyplace
    12,670
    11,829
    Central Virginia
  11. Mendel Leisk
    41,889
    I note the highish amp hours and lowish Cold Cranking Amps in the above pic. I think that would a dependable combo. I am clueless but heard hear that the higher the CCA, the more the reliance on thinner/more plates, which compromises amp hours and durability?
    Like doing tax returns, start the research early. (y)
    RCO likes this.
  12. bisco
    52,375
    200 bucks? scammed again by toyota.
    tomnmeg and RCO like this.
  13. alanclarkeau
    7,045
    7,593
    I'm hoping my 12v lasts the life (for me) of the car. My last 3 cars did.
    Jnaom and Mendel Leisk like this.
  14. bisco
    52,375
    mine too, but there have already been some gen 4 replacements. warranty, no doubt.
  15. padroo
    2,763
    2,252
    No problem with my battery. Even though the car is a 2016 I didn't buy it until Nov of 2017 and only has 1,400 miles on it.
    I have only put gas in it twice. If it were to fail it should be under warranty.
    I was just looking around to see what was available for the future, in another year or two some of these batteries will start to fail.
  16. alanclarkeau
    7,045
    7,593
    My last car, I sold at 4 3/4 yrs, and the battery was still fine. Similarly to yours, it was a late 2010 build, but I bought just before the end of 2011, so the battery was almost 6 years old at that stage.
  17. padroo
    2,763
    2,252
    Average Life of A Car Battery . How Long Does A Car Battery Last ?
    SO, HOW LONG DOES A CAR BATTERY LAST ?
    The average lifespan of a typical car battery ranges from two to five years, with four years being the most common age when the battery starts showing signs of wear down.
    There is a good chance the battery in your new car is a year or two old when you buy the car.
    My 2016 was two years old when I bought it and was sitting on the showroom floor with a dead battery.
  18. bisco
    52,375
    yeah, that's bad. fortunately, all three of my pri were fresh off the boat. unfortunately, i could have purchased a lot of 12v batteries for the extra i paid for fresh off the boat cars.:cool:
    pjm877, RCO and padroo like this.
  19. padroo
    2,763
    2,252
    I lost a 3 year old battery for my whole house generator last summer. It was just barely over the three year replacement period by days and it failed. It was a Die Hard from Sam's Club.
    My 2006 Dodge Dakota has it's original Mopar battery. You loose on one end and make out on the other.
  20. bisco
    52,375
    agreed. my 2004 generator battery, and 2005 dakota battery are still going. the generator has an automatic float charger, which must be helping.
    hope i didn't jinx myself.:oops:
    padroo likes this.
