Gen 4 buying decision.
Discussion in 'Gen 4 Prius Main Forum' started by Humannoyed, Jan 14, 2024.
  1. Humannoyed
    Humannoyed New Member
    Nevada
    I’ve been a big fan for a long time and think I finally need some help for real owners. I’ve decided my next car will be a Prius, and that a 6’6 driver like me isn’t gonna fit in the 5th Gen sadly. Are there notable differences in reliability Prius and PP in the 2020-22 years?
    I would only charge at home with L1 and my daily commute is about 18mi each way. a
    Im aware of all the specs but not the real world comparisons.
  2. JC91006
    16,501
    8,413
    6'6" , maybe you should look for a Rav4. Prius might still be a tight fit
    cthorsman likes this.
    49,842
    welcome!
    no difference, those are all good years.
    Humannoyed likes this.
  4. Humannoyed
    Nevada
    I test drove a 2021 LE and fit comfortably.
    Robert21PrimeLTD likes this.
  5. Robert21PrimeLTD
    57
    29
    Nashville
    I bought a used 2021 Prime Limited with 41k miles from my sister-in-law so I knew the full history. Have driven 5k since then (about 625 miles a month). Love the car. Keep in mind that the EV range is 25 miles at best and that it will take you up to 6 hours to fully charge the battery with the 120v level 1 that comes with the car. I purchased a level 2 (240v) charger and a full charge is now 90 minutes. I charge almost every day and sometime more than once. I have used only 24 gallons of gas in those 5k miles driven. . . I'm only 5'3 so I can't address fitting in but the interior feels roomy to me.
  6. bisco
    49,842
    ev range is dependent on weather, hvac use, topography and driving style and speed
  7. Mr.Vanvandenburg
    1,173
    413
    2020 Prius Prime
    A Prime seems to fit very well with your daily use and ability to recharge. I enjoy the electric only drive, even on the highway. You probably would use from 0 to 1 quart of gas per day. The Prime has a heat pump and works well in my milder climate, but with some pretty rare frosts. Used, a Prime with fog lights is easy to identify from the front as the limited model. It has the all the way around parking sensors, bsm, hud, etc.
    Robert21PrimeLTD and bisco like this.
  8. Doug McC
    Doug McC Senior Member
    1,011
    381
    Midwest
    2022 Prius
    We bought a 2022 Prius XLE Nightshade edition new in February of 2022 and love it. I’m 5’ 11” and I can’t put the seat all the way back and still drive it. Plus, even with a big winter hat on I don’t scrape the roof. So plenty of room for your height.
    I actually wish we could have found a Prime and would go that route. The 21 and 22 haven’t had any serious issues (just make sure to read the Owner’s Manual). They do take the 0W-16 oil as the only one to meet the 6B requirement.
  9. Bärlin
    Bärlin New Member
    Germany
    Four Touring
    So, my wife and I opted for the 2016 Prius Four Touring. The price was a crucial factor, and the fact that it came from a Toyota dealer was important to us. As it ages, it requires specific maintenance intervals, and I no longer trust independent workshops. The battery cost is much more reasonable compared to the Prime model. We would have had to charge it at home very often with the Plug-In version for it to be worthwhile. The Prius 4 EHV maintains its value well, even after 8 years (2024), it still holds significant value in Germany. It seems to be the last of its kind (considering there are only PHEVs now). Our car had 45k km / 28k miles and was purchased just this week. I will now add some insulation to the doors and tires. We plan to drive approximately 40k km / 25k miles per year. When it comes to tires, we are looking at fuel consumption test results.
    #9 Bärlin, Jan 17, 2024
