Gen 4 Coolant leak
Discussion in 'Gen 4 Prius Main Forum' started by Moloki, Nov 29, 2021.
Tags:
  1. Moloki
    Moloki New Member
    Cincinnati
    Two Eco
    My Gen 4 is losing coolant to about 1 inch in the reservoir. No codes, but no heat is the signal. No obvious leak, no drip. Mileage is steady at 48-54 mpg. Runs smoothly. No white smoke. Have smelled sweet coolant smell twice. Ran pressure tests, hot and cold with it holding pressure, boroscoped each cylinder at local Prius shop
    Ideas?
    52,351
    how much does it lose in 24 hours?
    is it different if you drive or don't drive?
    how many miles on her?
  3. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    Had mine repaired under warranty. You might have the same issue.
    V Sport Wagon, Reypac24 and dig4dirt like this.
  4. Ozark Man
    Ozark Man Member
    173
    64
    Mississippi
    Four Touring
    I discovered mine was a little low when I got it home from the dealer . I bought it certified with 22,500 miles. I probably added about a pint and so far after about 1500 miles it hasn't went down any more that I can tell. Hopefully if there was a problem it is fixed and they just neglected to fill it back up.
  5. MalachyNG
    MalachyNG Active Member
    304
    225
    Northern NY
    2022 Prius Prime
    If your shop couldn't find a leak are you sure it's not just you checked when it was too warm or cold? It the coolant in the reservoir goes up and down with temperature and use so as long as it's between the full and low lines you may not have a leak. Unless you mean it is 1" below the low line or it is losing 1" in a certain timeframe.
    Did they check all the lines for any leaks? You can usually tell if there's a pink crust near a line or connection, if it's a small enough leak it may mostly evaporate and leave residue instead of a puddle under the car. The weak heat is concerning. If you aren't getting answers from your local shop you may need to stop by a Toyota dealership
  6. DOHCtor
    DOHCtor Member
    162
    94
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Thread revival.. at the dealership where i work, we change way too much exhaust front pipes/heat traps.. they leak in the exhaust so no apparent coolant leak is detected but it does smell sweet.
  7. Prius2016excel
    46
    36
    England
    Excel
    I’m another victim I’m sad to report, see: 2016 - complete power loss / breakdown | PriusChat
    Out of interest DOHCtor do you know if the car is ok to drive indefinitely with this happening? I’m topping up the coolant as necessary and get white smoke out the back under heavy acceleration. Thanks.
  8. jteran5
    jteran5 Active Member
    413
    203
    2019 Prius
    XLE AWD-e
    Toyota should actually do a recall and get these replaced.... I have a 2019 and while I don't have symptoms (that I know of), I'm worried that I might experience it after the emissions warranty expires. I know it happened to someone here already where she had to pay around 2k out of pocket because she was past the warranty but it was for this exact failure.
    Prius2016excel likes this.
  9. Mukunda
    Mukunda Junior Member
    67
    starts with P148F
    then apply T-SB-0135-19 - replace Front Exhaust pipe.
    problem recurs, and then dealer does some patch work.
    once warranty of your Engine expires, they say engine gone needs to be replaced.
    this is what my experience from 2016 Prius
    Problem started at 43K, Engine died at 51K on 1st March 2023.
    Toyota is denying any recalls / Manufacturing defect.
    Reported to National Highway safety
  10. Seffy
    Seffy Junior Member
    St. Louis
  11. V Sport Wagon
    V Sport Wagon Active Member
    375
    131
    Southern California
  12. Mendel Leisk
    41,861
    @Seffy, what’s the story?
  13. Seffy
    Seffy Junior Member
    St. Louis
    I made a text post and got a message that it had to be reviewed by admin since it was my first post. Thats the last i saw of it! Basically, I have a rebuilt title Toyota and had to bypass the heat exchanger due to a leak. This is just a photo for folks to see what it looks like. Just connect those two “holes” Pretty with a loop of coolant hose.
    mike5100, Mendel Leisk and johnjamis like this.
  14. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    Did it still have the original coolant in it?
  15. Gary Rieger
    Gary Rieger Junior Member
    port townsend wa
    the dummy light is far right-side of dash instrument panel and is a 1/4 inch in size even more frustrating is the fact the main info section that tells you to stop and have coffee along with a ringing bell is not a part of the overheating or low oil warning system!!!
  16. sylvaing
    sylvaing Senior Member
    1,210
    514
    If someone runs Hybrid Assistant as part of their usual routine when driving, would the engine coolant temperature be any indication that something is wrong? I'm guessing the coolant temperature wouldn't increase as the coolant is dumped into the exhaust instead of recirculating back to the engine to cool it (and warm the coolant in the process).
