Gen 4 engine issues?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by DirtyShampoo, Jan 8, 2021.
  1. DirtyShampoo
    DirtyShampoo Junior Member
    Kentucky, USA
    Has anyone had any drivetrain issues with their gen 4? I’ve driven my 2017 less than 400 miles but it’s already giving me issues. The car stutters when cruising around 40 mph, I’ve had it nearly give out on me when pulling onto a main road, felt like I was hitting a speed bump about 3 times, it’s very aggravating because I got rid of my 2013 for similar issues.
  2. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    I haven't experienced anything like that in our 2017, but it only has 23k miles. What is the odometer reading on your car? I'm assuming you aren't getting any trouble lights or messages on the dash. Possibly you could take it to a Toyota dealer for a ride-along, but if there are no trouble lights you wouldn't be able to get any warranty coverage, so you would have to pay for a diagnosis.
  3. DirtyShampoo
    Kentucky, USA
    it currently has a little over 86k miles on the ODO
  4. AzWxGuy
    AzWxGuy Weather Guy
    979
    495
    Tucson, AZ
    2021 Prius
    Bad gasoline? Water in the gasoline? Try some Heet gasoline dryer maybe. Any effects noticed at idle? You also might want to remove the plastic decorative cover on the top of the engine and trace out the connectors and cables from the harness to the fuel injectors and the spark plug coils, and look for any other obvious damage to the wiring. I think Toyota still uses an insulated wire made with soy protein or some such that rodents like to eat. Lastly, consider a dealer diagnostic.
    kithmo likes this.
  5. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    I believe I know what you are talking about. It DOES feel like its shuttering but it is just very low RPM being driven by wheels. Get a scangauge or a basic bluetooth dongle and connect it to an app called torque to see what RPM's this is happening on. Mine is usually like 992 or something like that. I used to have a manual prior to my prius and the manual felt the same exact way when running ultra low RPMs. As far as loosing power upon take off, are you maybe hitting some kind of bumps possibly, it does decrease the power when hitting a bump, man hole cover, ect for traction control purposes
  6. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    If you had this with your previous car then it points to what @AzWxGuy says in his first sentence, contaminated fuel. I would run it low then fill up with fresh, Premium branded fuel from a different gas station.
    krmcg likes this.
